Sorry buddy, was out late today and didn't have a chance to get pics, will definately get some and post em up tomorrow night.
On a side note, been stopped now by two R33 drivers commenting on the SKYLINE panel :)
  • Replies 80
Posted Images
i did a setup like this on my 180sx i had a few years back. got the idea off a GT starlet that had a light up garnish. i just used a 8" neon and some alfoil to make it reflect like a headlight. worked well enough. going to do it to the skyline when i could be bothered.
Hey guys, I used to have one of the light up panels, believe it was genuine but who knows. . .
Used to until someone ran into the back of me anyways. the day after I got the car!!
Tried to get a replacement one but the only person I talked to who could get one wanted like $700 to get it in from Japan!
Ended up with the boring Silver painted panel. . .
The 'Skyline' writing has white paint on it applied from the inside, and the rest is just normal clear plastic, i think
Oh well
Later
Oh well
Later
yeah thats the genuine EL panel ones..
got a questions regarding this bread board ..
how do you cut it down to size neatly?
just picked some up for this other panel im doing... but instead of 5 rows that you need, its about 40 rows, but long enough to do the whole panel..
any hints?
  Al said:
I used a metal ruler and 'stanley' knife, then used a "bench mounted, grinding wheel" to smooth the edges. Or you can just use a file, it's only fibre-glass
yeah sweet
didn't get to see your post til now, but thats pretty much what i did anyway:)
cheers for that
might end up redoing my panel with 2 stage lights and run the 2V LED's that aare the 7000mva or whatever .. see how it goes
  • 3 months later...
Mine came stock with the car from japan, lights up blue. Didn't even no till i got home When i rang him up a few days later i asked him bout it and he said its an optional extra when u buy the car brand new over there, i'll take a pic at night and post it. i Dont know how its done and aint gonna try to find out on my own car, cause why f**k with somethin that aint broke haha
you can't have white pointing back unless it is the number plate light. otherwise cars may think it is a headlight.
i had a nice officer explain this to me one night. i didn't have any lights on my car, but i was just asking him because he had pulled me over because he was bored.
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
