This might not be new. I saw a thread somewhere .
Today I went to get another key cut.The key guy said tyhe key would only open the dors. If it was put in the ignition the the security system in the car would prevent start up.
There was a thread somewhere about Nismo Keys but I cant find it.
Where do I go from here?
HELP>
Ionlyhave one key and the numbers have been ground off.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/120655-keys/
I've had a generic key cut, and it works fine. In fact, I don't use my Stagea remote key because it doesn't work with my alarm, so there's no point in carrying around a key with the remote fob as my alarm triggers my central locking, as I'm sure yours would do if you have one fitted.
When I bought the car, I got the Stagea key w/remote fob and a standard Nissan key, and I then got an extra spare key cut to leave at home for emergency emergencies (i.e. in the unlikely event that TWO keys go missing).
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2224437
Yeah I got several cut as well, they are a patrol key.
That and when I got my alarm installed the remote lock/unlock which is on the standard nissan key doesnt work.
Other than that no they do not have transponders in them.
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2224679
I'm guessing the stagea's are like the R33 SII GTS-T.. although some have central locking from factory - NONE - repeat NONE have a chip in the key..
If you goto a decent lock smith (not just a small booth at the local shopping centre) - they should have a device that they can put the key into and it will tell them if it is chipped or not..
Had alot of trouble convincing a couple of locksmiths that you could get a blank cut..
also - doesn't have to be a specific key - once again - decent lock smith wil l have the right shape to match.. should be about $5
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2224685
lander nissan can get the blanks with the remote for the central locking..........i nearly had heat atack when told were 350 bucks each i asked if they came gold farkin plated oh nos for the blanks there are 3 different types all listed for the car 80600n is glovebox i think 80600na looks like main key 80600p and the remote one is 80600n/80601p.............. regards mike .................... :)
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2224701
i think when my baby arivess ill just get couple standard keeys cut and get the alarm set up for the central locking and window closers like the patrol is .at $345 a key for the remote ones i have paid for a alarm
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2230656
i my knowledge there is no immoboliser chip in the key..
best way to find out.. lock yourself in the car.. and start it up...
if it starts then you know for sure. your key isnt chipped..
it just central locks...
hence most insurance companies.. have 2 point immoboliser on your policy..
Edited by muck
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2233849
You cant get the Stag in gear unless the key is in. Is that an Immobiliser?
Presumeably if you hot wire it you still cant get it in gear?
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2237124
i think thats just a safety thing.. so u dont start the car when its in drive and go forwards...
i mean.. usually .. if u have central locking.. it will immobolise the engine at teh same time... so if u jump in.. lock the doors.. and then start her up normally... it shouldnt start... since the immobliser is armed....
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2237505
Yeah its a wire that runs from the selector somewhere to the bottom of the ignition, you'll also find you cant take the keys out of the ignition without having it in park.
I found that out the hard way, because mine is a manual converted it still had this wire, and hey presto a day came around that I couldnt get the bloody key out :( but thanks to the help of all the guys here telling me of this wire I now have it pulled open, permanently ;)
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2238022
I jumped (well just sort of sidled) in, locked the doors, it started! Ergo, no immobiliser.
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2238624
Finally got some keys.
The blank fitted the Stagea, the S13, 180sx and RMR30. Got spares for all.
Strange that the first key cutter said it couldn't be don. Then on the next level of Australia Fair, no probs.Patrol blanks.
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2260090
Patrol blanks you say...... Who would've guessed it :domokun:
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2261301
  • 3 months later...
what do these blanks look like can someone post up a picture
can you buy genuine blanks from nissan? or are there other aus delivered models that you could order blanks for that dont have a remote fob on them
standard nissan patrol blank is the go i had the local kwicky mart cut 3 for me it cost me 14 bucks . ive even concidered selling my remote one because you can re program them. its no good to me now as ive set my alarm up with their keyfobs to run the central locking and wind the windows up and im sure someone would want it. i know black widow can set the alarm and or imobiliser up to use the original remote key from nissan i just didnt go that way because i only had one original .
Edited by mike40sydney
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2547392
That's the problem, they all go on about the fact that they have a chip in them.. but.. they don't..
Some places have a electronic sensor that they put the key in and it'll light up if it's chipped.. most places just won't cut it..
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2547419
i sent the missus to get em cut and she told them there is no chip but they just looked at her as if she was stupid and said they cant be done.i went there next day and sorted them out and told them that they were the stupid ones as the quicky mart cut mine and they work fine and they still argued with me (farkin dickheads) their loss lol
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2548455
Don't you realise that most key cutters have a Chip on their shoulders.
https://www.sau.com.au/forums/topic/120655-keys/#findComment-2549160
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
