can you use any nissan key blank say something like the one below
i know there are 2 types of the nismo key going around a long and a short. I think the short fits the stagea. On the list of suitable models it includes models like the N15 pulsar so does that mean you could go and get a nissan genuine blank for a pulsar which doesnt have a chip or an immobiliser button in it and get it cut to fit the stagea? I would like a key with the black bit and the nissan logo at the top that is all and I am not paying top dollar for a remote key as I will be getting an aftermarket alarm. The key below is about $25 australian posted from a parts store in the states
Edited by mcnamg
https://www.sau.com.au/forums/topic/120655-keys/page/2/#findComment-2558791
If it the same as the Patrol key, it will work.
Thats right. The patrol blank fits Stagea, Silvia, R30 Skyline, the only thing I'm not sure of is whether you can get an unchipped blank with the black plastic surround. :D:O
https://www.sau.com.au/forums/topic/120655-keys/page/2/#findComment-2562131
i dont know but I guess that if the stagea doesnt use a chip as long as the key itself works then it doesnt really matter. The chip wont talk to anything but thats no big deal. The key I attached above was from an american site and as I said $25 and it is a model with the chip so not too much more expensive than a regular key
https://www.sau.com.au/forums/topic/120655-keys/page/2/#findComment-2562333
  • 1 month later...
Picked it up today from nissan, in stock and $11 each.
Key cutter guy had them in stock too, $7 including cutting for a generic one without the plastic or the nissan logo
BTW I love the creative nissan part number
https://www.sau.com.au/forums/topic/120655-keys/page/2/#findComment-2731176
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
