As the title says here is a dyno sheet for a set gt-rs's on a 2.9l gtr engine. It needs bigger injectors as you can see it hasn't fallen over yet. Will post another sheet once the bigger injectors go in.
all the usual mods have been done, including these relavant ones;
gt-rs turbos
uas extrude honed manifolds
ces race style dumps and front pipe
trust tr exhaust
hks 280 10.7 intake, 288 11.0 exhaust cams
1mm o/s intake valves
cnc ported head
cp forged pistons
eagle h beam rods
stroker crank
power fc
z 32 afms
any questions just ask.
this run is at 16 pounds, pump fuel and injectors at max duty cyclepost-9006-1149294536.jpg
https://www.sau.com.au/forums/topic/120686-rb26-gt-rs-dyno-result/
  • Replies 73
Posted Images
Nice result, but as per the above posts I agree that you have more power to come as the curve is still rising.
You have a similar setup to me Gav's Dyno Graph, however note that I have shorter final gears from a GTS4, so a direct km/h comparison isn't possible.
I still have some mixed emotions over the GT-RS terbs, however it is apparent (to me at least) that to get the best from these turbs on a 2.8L you still need to get some serious airflow through the engine. Big revs, high lift/long duration cams (I'm changing my Step 2 264 IN to a 270 duration) and head porting really makes a difference.
Good luck and drop me a PM if you want to chat.
Cheers
Gav
hey guys, to answer some of the questions, its a modified rb 30 crank, eagle rb26 rods, this may sound strange but i dont even know what BP on that dyno chart means (im an engine machinist, and know very little about dyno set up), only just got the car back so not sure what rpm it hits full boost at but ill let you know.
BP is the barometric pressure. The usual is around 101 or there abouts. At a lower atmospheric BP, the engine will make less power due to the decreased density of the air. So with a lower BP, Shootout mode will correct the reading (ie inflate it) to match what the engine would make at roughly 101 (or whatever the Shootout mode considers standard). So like the temperature probe, false readings can give misleading dyno results. Ie low BP = increased power just like high ITs = increased power.
Anyways nice power man, keep up the good work. Once its finalised it must be a real beast, not that it isnt now already! And yeah, more details please!
I modified the crank, so that i could use a 26 block, instead of an rb 30 block, so that all the outside components would fit up with out modification. The pistons are a custom order, with 22mm pin, the only rod modificatonn, is re-bushing to 22mm pin
Very interesting. So I assume you offset ground the crank to de stroke it a bit? Did you hardchrome it first, or are you running custom big end shells?
Was there enough meat in the ringlands to run such a low pin height (and 22mm pins)?
The crank is de-stroked slightly, and heavily modified, using std rb26 shells (rb30 big ends are larger than rb26). Yeah the ring lands are fine, the pin is high, but no higher than on a lot of other long stroke engies. Details on the crank mods sound vague, but i dont have exact measurments of what i did. i made templates of the shapes i made everything so i can do it again, and am in the process of figuring out if i can offer the conversion at an economical price (there are a lot of hours of labour in the modifications). To do all the mods you need a lathe, mill, crank grinder and engine balancer. But should still be able to do something vastly cheaper than japanese alternatives.
Edited by mark99
