mark firstly nice work,
Can i ask did you extend the block? as it sounds like you have increase the stoke and allowed for it in the piston design (pin height) which will work but has serious long term issues as the stoke to conrod ratio will be extreme as the rb26 run a low ratio std. What this means is the rods have pivot alot more through each stroke and adds alot more load (wear) to rods, bearings and crank.Guys like sydneykid can explain alot better then me. Please dont take this the wrong way as i know it works and its a great effort to have a go and do something custom yourself much cheaper than buying japanise kit but i believe the reason the japan kits only run a slight increase in stoke is mainly due to this isssue.
pete
Edited by pnblight
  • Replies 73
Posted Images
pete
It will make massive torque though with rods that short. Which is why the jap stoker kits tend to make more torque then their minimal stroke increase would imply.
There are three things to keep in mind when comparing rod / stroke ratios and power output;
1. Longer rods go slower through TDC, keeping the total combustion chamber smaller, that’s the actual chamber in the cylinder head plus the exposed part of the cylinder. Thereby giving an increase in combustion pressure, this means more torque per firing.
It’s been while since I did the numbers, but from memory, comparing an RB30 conrod length to an RB26 conrod length means that the combustion pressure is around 2.5% higher (with the same compression ratio). This means a noticeably improved efficiency of combustion.
2. Larger rod ratios keep the rod more vertical, reducing the side loads on the piston and reducing friction between the piston and the bore. Using the same RB26 vs RB30 conrod comparison sees a reduction in side loads of around 10%. I don’t know the total friction numbers for an RB but if we assume that they are similar to a SB Chevy where about a quarter of the friction comes from the pistons. This means a reduction in friction of around 0.5%, not a lot but certainly better than adding friction.
3. The maximum piston speed of an engine using an RB30 rod occurs a bit later in the cycle compared to an RB26. Which means it is closer to maximum lift of the camshaft. Hence when the piston is moving the fastest, the valve is more open, causing less of a restriction. This means better filling on intake and better exhaust flow.
There are a number of other benefits from a higher rod stroke ratio such as slower more effective compression to squish zones, longer dwell at TDC means higher preignition tollerance, less detonation etc.
It is also worth mentioning that #2 above means that an engine using an RB30 length of conrod (compared to an RB26) will have less cylinder wall and piston wear. More relevant is that it will have a far less chance of breaking a conrod due to the lower side loads.
The bottom line, given the choice, I would choose the RB30 rod stroke ratio over the RB26 every time.
:D cheers :)
Edited by Sydneykid
Yeah, what SK said. Basically longer rod to storke ratio is better. However due to me wanting to retain the factory block yet increase the stroke, something had to compromised, thus the low rod to stoke ratio. But i dont cosider it too big a trade off, its not that much worse than other jap brand stokers, yet gives me more capacity at vastly reduced price. The other thing to note is that some the benefits of longer rod to stroke, ie better cylinder filling, are most notable on engines with very poor breathing, ie restrictive induction and heads. Something a turbo charged engine has less to worry about.
So whist in an ideal world i would have preferred a longer rod to stroke ratio, in the real world, for what i wanted, std block, more capacity, affordability, something had to give
Oh and redline is 8000 at the moment, but will be raised once bigger injectors go in.
Edited by mark99
Did you consider the OS Giken 3 litre solution?
Longer cylinder liners.
But using the RB30 length conrods and a 38 mm spacer.
Instead of the RB26 length conrods and an 18 mm spacer.
Then you could have used a standard RB30 crank and the oversized pistons for 3.1 litres. I believe the liners and spacer plate would have cost less than a bespoke crankshaft.
:w00t: cheers :D
I still think this setup would be awesome for a street gtr running mild say up to 400rwkw maybe more, depends where it proves to be reliable. :w00t:
Being able to run 2.9ltrs and retain the stock rb26 block has huge advantages for those that wish not to run the rb30 block.
Mark99 I take my hat off to you for going down this route and sharing the experiences - as Cubes says, an interesting alternative and certainly has the potential for a good streetable GT-R.
I'm not convinced of the cost benefits, however as I have a similar power curve with more headroom potential (i.e. rpm) using an HKS stroker crank and offset pin pistons. This crank has the advantage of being counterweighted and less prone to inducing destructive harmonics at high rpm. A good aftermarket damper is obviously part of the package.
The HKS "entry level" stroker cranks and pistons are now in the order of $6k to $6.5k in Australia. It would be interesting to see what the true cost of modifying the RB30 crank and making custom pistons is compared to the HKS kit.
Again, not meant to be a critisism but just some personal experience I'd like to add to the discussion. Will certainly watch your progress with interest!
:w00t: cheers :D
Average cylinder pressure over time is actually greater with a short rod than with a long rod. The reason for this is that maximum leverage on the crank occurs when the rod and crank are at right angles. This condition happens quicker with short rods leading to more torque.
That said, longer rods will always be preferable (a rod ratio of about 1.75) for the other reasons sydneykid mentioned.
Edited by Mik
Is that in reponse to my #1?
If that is the case, then I am not sure that we are talking about the same thing.
With the longer rod, the piston is around TDC longer for the same number of crankshaft rotation degrees. Hence “around longer” means while the combustion is actually occurring, That’s why I say “Thereby giving an increase in combustion pressure, this means more torque per firing”.
The angle of the rod at ½ stroke is something altogether different. Where the longer rod is also an advantage as the right angle to the crank occurs earlier in the combustion process. Therefore imparting more torque at that time.
Or have I missed something?
:teehee: cheers :O
Edited by Sydneykid
Thanks for the interest guys. Yeah really broad power was what i was after for street use.
Gav, for that price is that a fully counter weighted or semi counter weighted crank? While i agree horses for courses, im hoping the cost to be sustantially less than that.
Pete, at this stage, the same as any rb30 crank, so far what i have done seems to have no adverse effects on the crank, but iil keep you posted.
Edited by mark99
Pete, at this stage, the same as any rb30 crank, so far what i have done seems to adverse effects on the crank, but iil keep you posted.
Address of where to send my crank to ??
I believe it's for a "Step 2" crank and I believe fully counter weighted (unless someone can say otherwise?) as shown here:
HKS website states these are good for 9,000 rpm and 588 engine kw, but I suspect this is somewhat conservative.
Can you explain how a longer dwell at TDC gives more tollerence to preignition???? The longer the time it spends at TDC the more heat combustion chamber consumes meaning more chance of pre ignition. You definately cant get the same timing numbers into rb30/26 compared to a rb26 both with similar dynamic compressions.
fixed ur quote up rob (R31Nismoid)
Edited by rob82
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
