mark firstly nice work,
Can i ask did you extend the block? as it sounds like you have increase the stoke and allowed for it in the piston design (pin height) which will work but has serious long term issues as the stoke to conrod ratio will be extreme as the rb26 run a low ratio std. What this means is the rods have pivot alot more through each stroke and adds alot more load (wear) to rods, bearings and crank.Guys like sydneykid can explain alot better then me. Please dont take this the wrong way as i know it works and its a great effort to have a go and do something custom yourself much cheaper than buying japanise kit but i believe the reason the japan kits only run a slight increase in stoke is mainly due to this isssue.
pete
Edited by pnblight
  • Replies 73
Posted Images
pete
It will make massive torque though with rods that short. Which is why the jap stoker kits tend to make more torque then their minimal stroke increase would imply.
There are three things to keep in mind when comparing rod / stroke ratios and power output;
1. Longer rods go slower through TDC, keeping the total combustion chamber smaller, that’s the actual chamber in the cylinder head plus the exposed part of the cylinder. Thereby giving an increase in combustion pressure, this means more torque per firing.
It’s been while since I did the numbers, but from memory, comparing an RB30 conrod length to an RB26 conrod length means that the combustion pressure is around 2.5% higher (with the same compression ratio). This means a noticeably improved efficiency of combustion.
2. Larger rod ratios keep the rod more vertical, reducing the side loads on the piston and reducing friction between the piston and the bore. Using the same RB26 vs RB30 conrod comparison sees a reduction in side loads of around 10%. I don’t know the total friction numbers for an RB but if we assume that they are similar to a SB Chevy where about a quarter of the friction comes from the pistons. This means a reduction in friction of around 0.5%, not a lot but certainly better than adding friction.
3. The maximum piston speed of an engine using an RB30 rod occurs a bit later in the cycle compared to an RB26. Which means it is closer to maximum lift of the camshaft. Hence when the piston is moving the fastest, the valve is more open, causing less of a restriction. This means better filling on intake and better exhaust flow.
There are a number of other benefits from a higher rod stroke ratio such as slower more effective compression to squish zones, longer dwell at TDC means higher preignition tollerance, less detonation etc.
It is also worth mentioning that #2 above means that an engine using an RB30 length of conrod (compared to an RB26) will have less cylinder wall and piston wear. More relevant is that it will have a far less chance of breaking a conrod due to the lower side loads.
The bottom line, given the choice, I would choose the RB30 rod stroke ratio over the RB26 every time.
:D cheers :)
Edited by Sydneykid
Yeah, what SK said. Basically longer rod to storke ratio is better. However due to me wanting to retain the factory block yet increase the stroke, something had to compromised, thus the low rod to stoke ratio. But i dont cosider it too big a trade off, its not that much worse than other jap brand stokers, yet gives me more capacity at vastly reduced price. The other thing to note is that some the benefits of longer rod to stroke, ie better cylinder filling, are most notable on engines with very poor breathing, ie restrictive induction and heads. Something a turbo charged engine has less to worry about.
So whist in an ideal world i would have preferred a longer rod to stroke ratio, in the real world, for what i wanted, std block, more capacity, affordability, something had to give
Oh and redline is 8000 at the moment, but will be raised once bigger injectors go in.
Edited by mark99
Did you consider the OS Giken 3 litre solution?
Longer cylinder liners.
But using the RB30 length conrods and a 38 mm spacer.
Instead of the RB26 length conrods and an 18 mm spacer.
Then you could have used a standard RB30 crank and the oversized pistons for 3.1 litres. I believe the liners and spacer plate would have cost less than a bespoke crankshaft.
:w00t: cheers :D
I still think this setup would be awesome for a street gtr running mild say up to 400rwkw maybe more, depends where it proves to be reliable. :w00t:
Being able to run 2.9ltrs and retain the stock rb26 block has huge advantages for those that wish not to run the rb30 block.
Mark99 I take my hat off to you for going down this route and sharing the experiences - as Cubes says, an interesting alternative and certainly has the potential for a good streetable GT-R.
I'm not convinced of the cost benefits, however as I have a similar power curve with more headroom potential (i.e. rpm) using an HKS stroker crank and offset pin pistons. This crank has the advantage of being counterweighted and less prone to inducing destructive harmonics at high rpm. A good aftermarket damper is obviously part of the package.
The HKS "entry level" stroker cranks and pistons are now in the order of $6k to $6.5k in Australia. It would be interesting to see what the true cost of modifying the RB30 crank and making custom pistons is compared to the HKS kit.
Again, not meant to be a critisism but just some personal experience I'd like to add to the discussion. Will certainly watch your progress with interest!
:w00t: cheers :D
Average cylinder pressure over time is actually greater with a short rod than with a long rod. The reason for this is that maximum leverage on the crank occurs when the rod and crank are at right angles. This condition happens quicker with short rods leading to more torque.
That said, longer rods will always be preferable (a rod ratio of about 1.75) for the other reasons sydneykid mentioned.
Edited by Mik
Is that in reponse to my #1?
If that is the case, then I am not sure that we are talking about the same thing.
With the longer rod, the piston is around TDC longer for the same number of crankshaft rotation degrees. Hence “around longer” means while the combustion is actually occurring, That’s why I say “Thereby giving an increase in combustion pressure, this means more torque per firing”.
The angle of the rod at ½ stroke is something altogether different. Where the longer rod is also an advantage as the right angle to the crank occurs earlier in the combustion process. Therefore imparting more torque at that time.
Or have I missed something?
:teehee: cheers :O
Edited by Sydneykid
Thanks for the interest guys. Yeah really broad power was what i was after for street use.
Gav, for that price is that a fully counter weighted or semi counter weighted crank? While i agree horses for courses, im hoping the cost to be sustantially less than that.
Pete, at this stage, the same as any rb30 crank, so far what i have done seems to have no adverse effects on the crank, but iil keep you posted.
Edited by mark99
Pete, at this stage, the same as any rb30 crank, so far what i have done seems to adverse effects on the crank, but iil keep you posted.
Address of where to send my crank to ??
I believe it's for a "Step 2" crank and I believe fully counter weighted (unless someone can say otherwise?) as shown here:
HKS website states these are good for 9,000 rpm and 588 engine kw, but I suspect this is somewhat conservative.
Can you explain how a longer dwell at TDC gives more tollerence to preignition???? The longer the time it spends at TDC the more heat combustion chamber consumes meaning more chance of pre ignition. You definately cant get the same timing numbers into rb30/26 compared to a rb26 both with similar dynamic compressions.
fixed ur quote up rob (R31Nismoid)
Edited by rob82
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
