I was having hunting problems and I think it was my O2 sensor, so I picked up two from my mechanic one from an rb20 with a small dent in the side, and a 300zx one which he said would work and looked the same.
The old sensor didnt survive the removal process (it was in pretty tight) so I cant put that one back in, so I put in the new one, which had a different sensor, looked like a vent you see on the top of delivery vans, the old one had a series of holes... Anyhow I crossed my fingers, started her up, ran ok, went for a drive around the block, and half way it started running really badly and beginning to smell like something was burning.. I went straight home, lifted the bonnet and the new O2 sensor was smoking!
Sorry for the lengthy post, but im a bit stuck for options, I have one more sensor, but I dont want to use it if its going to do the same thing, I need to know if I did something wrong installing it, or it is completely the wrong type of sensor, If i find the other type can I get away with changing the plugs over? I cant really wait 3 weeks to get one from japan, I am a computer tech and need my car for work!
Any help is greatly appreciated
https://www.sau.com.au/forums/topic/120699-my-new-o2-sensor-melted-help-please/
Sorry for the question but I have to ask. You sure you wired it up right? Did the sensor you put in have 3 wires? Was that sensor for 300zx's?
If your positive then i'd recomend grabbing a new sensor. You can use universal sensors made for EL falcons that you can find for $70 odd bucks and they work perfectly.
Cheers
some nissan sensors use different pins on the plug for power/earth signal, so may have been unlucky and stuck one in with the pins in the wrong spot.
check you original sensor, it should have a red, white and black wire. Make sure that the new sensor has them in the same order. The black and red can be swapped around as they are only for the heater element but the signal has to be right.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
