I just purchased my r32 1989 with turbo
The chassis is from a non-turbo skyline. the plate says RB20DE
Im not sure whether it was a full RB20DET conversion or a RB20DE with a turbo upgrade
Is there a big difference?
Im not sure if i got ripped off
Are the rb20de and rb20det parts compatible?
Could someone please tell me a little bit more about the engines. And clues for me to look our for , so i can identify if the engine is full transplant or just a bolt on stock turbo
Pics would be great.
Cheers
https://www.sau.com.au/forums/topic/120782-rb20det-or-rb20de-with-turbo/
you can find out what engine you have by looking at the engine number located on the lower rear left of the cylinder block.
As for the differences not sure with the rb20 engine. I have a rb25de and planning on putting a turbo on in, it wont be able to handle as much power as the rb25det but should be as fast as or faster than a stock gtst, hoping for 300rwhp at 7-10psi.
try a search in the NA Performance section
-michael
the engine says " RB20 and then the engine number i think "
heres a dodgy pic of the engine bay
Is rb20de really that bad with a turbo ?
The last owner had it for longer than a year
Im also interested in resetting the ECU. would that be a good idea?
I guess you could look for things like where the oil feed and water lines ect to the turbo are coming from. See if it just looks like someone has tapped into the sump or the block for oil or whether it all looks like stock piping etc.
Do you know how much boost you are running? If your running anything more than 7psi i would bet that your engine would be pinging like hell if it was a rb20de engine. What does the car drive like? They probly just put a whole det engine init. Have they converted the car to 5stud etc?
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
