Hi just wondering if you have any information on r32 ignition some punks stole my black beast but ran out of fuel in the process they stuffed my ignition should i suss it out and attempt fixing myself or take it to a shop where i could be ripped off im not sure on the whole ignition thing so thanks heaps for the other tips they were realy helpfull
many thanks
https://www.sau.com.au/forums/topic/120809-stolin-skyline/
stuffed my ignition........the whole ignition thing
Umm yeah be a little more specific, like is it the steering lock assembly, the ignition switch (attached to the back of the steering lock assembly) or is it the ignition cylinder (the part the key goes into).
86-91 R31 Skylines and Pintara
89< R31 Pintara
87-91 N13 Pulsars
83-89 Z31 300ZX (make sure it has the key release push button)
83-87 Y30 Cedric or Gloria (make sure it has the key release push button)
90-93 NA31 Cefiro (i'm pretty sure....make sure it has the key release push button)
89-95 J30 Maxima (some had the same)
87< N13 NX/100NX/EXA (some had the same)
92< K11 Micra (some had the same)
.....you get the picture
These listed used the same steering lock assembly's and ignition cylinders as the r32, that means if you took one out of a r31 or n13 it will bolt straight up to your r32.
Find a R31 or a N13 Pulsar would be your best bet as they're locally built and pretty common.
If you do choose to use any other donar model, the best thing to do is to take yours off and bring it with you to a wrecker.
Go to a wrecker find an old r31 or n13, get the steering lock assembly off(the ignition cylinder should be still inside of it, it'll be one unit), it probably won't have any keys so take it to a locksmith, give them the steering lock assembly and your key for the car (they'll need it to match the second hand ignition to your key). If your existing cylinder still turns ok then bring that with you, they might be able to still use it.
If you've got the original/genuine nissan key for your car then even better. On the original keys they stamped a number, the locksmith can use that number to cut you a set of brand new keys. They'll only suggest to cut new keys are if your original keys are too worn to use......yes ok even though your original key seems to work fine in the locks, it's still worn and you need a new set anyway...believe me.
If you don't have the original keys, just give them what you've got, they'll work it out.
It's definitly not DIY job......but if you just so happen to get keys with it from the wreckers(unlikely) or if you buy genuine you can just unbolt your old one and bolt up the new one, you'll just have to put up with the inconvenience of not having one key for your boot, doors and ignition.
If your going to bolt it up yourself you may have trouble removing the old one and putting on the new one. If you do get to that stage just post up again and I'll help you through it.
Hope thats what your looking for :D
PS- Get an immobilisor
EDIT: Added info
Edited by KeyMakeR33
https://www.sau.com.au/forums/topic/120809-stolin-skyline/#findComment-2228919
hey man thanks heaps for your info hey hopefully will be able to do it this weekend i hope so the beast will run the streets again
many thanks
p.s I have the original keys and have a few lads together for the fix
pp.s it's got a loose steering colum and where the key goes into is all pulled apart
Whats your thought on kill switches is that those red keys you see in some cars, what a they like do they stop the theives from doing this again or can they still get around that stuff
Edited by devos2be
https://www.sau.com.au/forums/topic/120809-stolin-skyline/#findComment-2232207
If "where the key goes into" is all pulled apart it sounds like the cylinder/barrel is stuffed.
And a loose steering column? Does the whole column move up and down side to side?
When you say kill switches I'm assuming you mean immobiliser's.
The first thing i did when i bought my skyline was get an immobiliser fitted.
Immobilisers can be activated in a few different ways depending on which one you buy.
They can either have a code pad, a remote to activate/deactivate the immobiliser and lock/unlock the central locking, or just a switch hidden in the car.
In all cases the immobiliser when activated, cuts power to the ignition switch or doesn't allow your fuel pump to turn on, so even if you put your key into the igintion and try to turn the car on, it won't start, therefore you can't go anyware.
For a thief unless their really smart in auto electrics and had the time to try and figure out where underneath the dash it was wired up, or they were the one that wired up the immobiliser, they won't be going far.
EDIT: grammer
https://www.sau.com.au/forums/topic/120809-stolin-skyline/#findComment-2232369
post-28526-1149577391.jpgYeah i hear ya guess ive learnt my lesson now but,
the steering colum is loose like up and down,is the ignition barrel the whole piece or...
thanks again mate will post again to let you know how it goes ccccccchhhhhhhhhhhhheeeeeeerrrrrrrss
the devos
https://www.sau.com.au/forums/topic/120809-stolin-skyline/#findComment-2232416
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
