Ok just got off the phone from Josh - apparently he emailed a text based version of the map through to Joe! He was under the impression that this had all been ok'd...but anyway, he is posting the map tonight when he gets home from work.
General notes:
Date - Friday 21st March
Time - 8pm
Location - Carpark at the end of Ellam St in South Perth (near the river, kind of behind South Perth Hungry Jacks etc)
The cruise map apparently is quite long and should be wild.
Zanda - gotta get the old skool r30 out and about on a cruise.. what you'd lose in speed you'd more than make up for with bass.. :D
ride is cool - your lovely lady coming along or is it going to be a boys club outing?
We'll be there. I'll be in the Silvia and Leilani will be in the GT-R. I know it should be the other way around but it's her daily driver not mine. Should be interesting with the PowerFC and Boost Controller being installed on Tuesday.
Cheers
Brendan
Brendo
Can I try your PFC Commander?
It looks like I need a real old version Commander to be compatible with my PFC.
BTW - my old Commander of the S15 is for sale. Will cut you a special deal as the cord is shorter now than std (but should be OK with the extension cord). I have also sorted out how to modify the mini din plugs to fit.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
