SilviaWA and SAU cruise
hks-s14
 Share
I sorry HKS-s14, I think I was bit busy with uni work so didnt relised he set up the cruise on 21st!
but as you probably know we are having cruise on 23rd and many of us will be saving our $$$ for the day.
I am sorry we can not meet up on this cruise but I know we will soon or later for bigger and better cruise.
anyway you polly still have hard core cruisers on the day!
I wish safe and fun cruise for you all!
cheers
Joe
Perth Cruise Nazi! :D
Originally posted by hks-s14
So are any of you girls coming along???  Or are you all too scared of getting the chop by Silvia's??? :P
*the bait is out there - waiting for a bite*
hehe:)
Sorry not me as previously stated got the cruise on Sunday and shelling out heaps to have things done on car my bank account cant handle the price of fuel as well :P Have fun boys!
haha yes very very buggered - and u all were just thinking i was doing the typical whinging chick thing! Hey do u know what brand they were? just curious - because when they were working they were doing a good job for a lowered car! Just KYB's! PS - if you saw the car too its not always that dirty honestly haha!
Anyway this i sway off topic so i'll shut up before i get slapped by Troy!
Reckon its a pity that more SAU people wont be reprezenting..
Campbell and I will be there.
Apparently the price of oil fell again overnight. The fuel companies should drop their prices today under threat of investigation by alan fels.
pity more pplz aren't going to come along - well doesn't sound like it anyways... oh well - their loss i guess...
as for the no $$ for fuel excuse - u got enuff $$ for buying a skylor - can't tell me u don't have the $$ to use it! :) hehehe
ps - me expecting much abuse here.. :D
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
