Bolt on type, need repair on one bend just before it attaches to the cat, eveything else is perfect working order, 3" piping and a 4" tip, full stainless system, i assume it will only cost $80 or so for a local shop to cut out the bend and make another mandrel bent corner (cheaper if pressure bent)
photos of system and a close up of the bend are here
i'd like to sell this asap as i have no use for it as i wanted a 3 1/2"system not a 3" and i bought the wrong system hehe, so im out of pocket about $680 (what i paid for it form hikari performance (was listed for $780 on their website)
PAID $700
SELL $600 (BARGAIN!)
call 0411 50 54 58 or email [email protected] or just reply to this thread or PM me :D thanks guys
  • 3 weeks later...
Offer - $325 pick-up in Melb. Can send a friend. Let me know if interested as friend is driving up to Bris to visit us on Thursday. PM me and we'll talk acc't details if interested.
iijj
iijj
dude that offer isnt even worth considering
Originally posted by Raza
will it fit on a r33 4 door
not as it is now but when u get the dent repaired u can tell them to do it so it will fit, may cost an extra $10 but really shouldnt cost anymore as its the benmd they charge for doing, they will be able to make it fit
cmon $600 is a bargain for this exhaust, full stainless steel, ya'd pay $1200+ easily for something of this quality brand new, but i must stress its $600 FIRM im losing enough money on this as it is :D
  • 4 weeks later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
