  • 1 month later...
Bump,
anyone, need these ASAP as we're getting number plates made up for members of SAU QLD Inc.
http://www.skylinesaustralia.com/forums/in...t&p=2224768
I need the fonts or high quality copies of the logos please.
ta in advance.
Mud
how much is this costing and do u have to have a ABN to do this in QLD
https://www.sau.com.au/forums/topic/120856-fonts/#findComment-2335771
$330 for the artwork and regular 3letters+2numbers plate cost thereafter.
yeah need an ABN, or in our case an incorportated club
found the www.skylinesaustralia.com font (aggie)
still need high qualtiy GTR badge style SAU logo??
anyone???
https://www.sau.com.au/forums/topic/120856-fonts/#findComment-2364040
  • 3 weeks later...
