ARC kit is the way to go. no doubt. I have NFI what paulR33 is trying to say about a stock GTR cooler (better than GKtech? or better than ARC?), but considering you have a GTST whether a stock GTR cooler is better or not is not really relevant...
ARC kit will be much nicer than the chinese kits. i say go for it.
he's saying GTR core is better than Blitz, ARC etc...
maybe for the GTR's...as having the plenum on that side means they have short piping....which is what you get when using arc/blitz LM on a GTS-T....
  • Replies 41
Posted Images
I think the one your thinking of is a PWR cooler??
The design of the ARC one is similar to the blitz LM. Does anyone know if there is much of a difference between the two, or are they much of a muchness?
How big are the inlet/outlet and the size of the piping?
fair enough. I'm not sure that he is right though. sure the calsonic GTR coolers are good, but I would thing a properly sized ARC one would be better. plus for a GTST it's a moot point as 1. they dont come with a GTR cooler, and 2. if you bought and fitted one it involves some fairly lengthy piping. so not really relevant to this guys question at all.
ehheh thats what i was getting at...they might be good on a GTR...but the gtr uses shorter piping with the plenum on the same side..whereas the gts-t needs to come up and over the radiator...so there's your extra piping...thats why i beleive that if you have the money and can justify spending it on a cooler, the turn flow kits are the way to go
this is mine
LOL, I was just looking at that pic trying to work out how that works with the twin entry, then I realised that your car is a GTR - i.e. twin turbo.....
Looking at the turn-flow kit, would the "turn" to come back under the radiator be restrictive, or is this a better design than the regular kits that go over the radiator? Looks like one advantage of this kit is that it uses the factory piping.
http://www.arcinter.co.jp/arc/products/ic/ic2.html
Its the core design that makes all the difference.
note the flared tubes on the inlet side of the core. On any other cooler the air hits 50% or more of a brick wall. ARC reduce this restriction to a minimun. It is also worth noting that I previously had over heating problems which are no existant now. Flow through the core is also improved.
That was going to be another question I meant to ask. Is it likely that the car could overheat with a FMIC in place, being that it sits in front of the radiator. Is it worth looking into a better radiator and/or colder thermostat?
I suppose a colder thermostat might be a good idea, it is pretty cheap insurance to prevent overheating. Going for an aftermarket radiator might not be required though.
I suppose if I have any problems, I can always throw the standard cooler back in until I get it fixed.
Dezz..that R34 Nur in your avatar..It came into work and I got to drive it..its breathtaking to see it in person.Owner currently sellin it:(
:D
How much is he asking? I need to know how many banks i need to rob so i can buy it off him :D:ermm:
Again guys you get what you pay for.
I bought one of the GKtech coolers and while the cooler itself was very good, im now going to have to fork out more to get custom stainless steel pipes made up for it as the gk pipes have the most piss poor fit of any kit i have seen.
none of them line up when fitted and we had to cut 2 inches out of one pipe just to fit it to the cooler.
Bleh you cant expect to much from a $400 kit.
:D
I didnt ask him how much but asked why he was selling it (as I think he bought it a few months ago)and he said it was too much money to be tied up in a car.I did see it for sale on a trading site here going for less than $NZ250,000 so hm you probably need to rob just one bank:P
thats interesting hayden...I havent heard any negative feedback from anyone else....
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
