Hey guys,
Just wondering, when your intercooler pipe comes off while giving it a bit....can it cause much damage to engine/turbo/anything??
mine came off this evening, and I have never experienced it, and as I am kind of new to turbo performance, I guess you could say Im a bit nervous incase there could be damage.
Morgs who was there, says these things happen! and are normally all good, just a time hassle to get it back on.
My car has only cat back, pod and a turbotech boost controller running 9psi - could this boost controller have caused the blow out? Say a spike somewhere?
Ive taken it off and put the stock part back on just for now.
Cheers guys,
Chris
https://www.sau.com.au/forums/topic/120872-intercooler-pipes-blow-off/
Sounds like you either don't have a good enough rolled edge/retainer on the metal pipe or your clamps were either not tight enough or not up to the job.
When the exhaust is hot you could end up with a lot of flame out the exhaust like I did, melting the rear bumper, but you have to drive a little way for that anyway. Otherwise you could just clog up your plugs with carbon but no real damage will occur if you stop pretty soon after blowing the hose.
GTRgeoff - thanks for the reply mate!
Basically I pulled into the first side street as the engine shut down, no air getting in, stalled basically.
So fingers crossed its all good!
Cheers mate,
Chris
meh don't worry it happens all the time, will probably stall pretty quickly because afm is seeing heaps of air but very little gets to the engine.. the biggest pain is getting to the lower ones under the front bar.
Some fixes:
Bigger lip on the end of the cooler pipes
New cooler hoses, preferably silicon which don't baloon out under boost
Proper truck style clamps instead of those crappy screw type ones that Nissan gave us.
Yeh ive had the same thing happen about 4 or 5 times :D still have leaking problems to. Nissan clamps suck. None of the hoses justjap gave have come off but the nissan ones will need tightening using a spanner not a screwdriver. Also i noticed that my silicon hoses went softer pretty quick so after a week or 2 u might wana retighten. About 5 of mine were loose after the first week but now they seem ok.
well,
bit of a pickle again....
this evening, noticed he car was spooling louder and earlier
(I took the turbotech b/c off, so stock boost now) came onto main road, 1st gear, changed at 2.5k, into 2nd, went to bout 3-4k and the motor shut down again, spooled really loud this time.
Something must be up with one of the rubber joints yeah?
I cant see any splits, could be underneath where I cant see?
A friend thought maybe theres an electrical fault, i.e. a sensor is stuffed?
any ideas guys?
I can drive the car, but have to keep it off boost, which is likechanging at 1k revs!!
Not good
:blush:
hhhm.... thats odd, when i fitted my cooler yesertday i noticed that there is throttle lag when you drive normally but when you punch it you dont notice anything.
my car screams now from turbo spool and induction noise but i dont think its a bad thing.
although my car does now flutter heaps, sounds like wastegate flutter to me.
hmm...apparently everything seems fine.
My mechanic tookitfor a drive and said nothing went wrong, boosted well, couldnt get it to happen!
he even sprayed some carby cleaner over the pipes, gave the car a rev, and the carby cleaner didnt get sucked in, hence no leaks anywhere...but its still got a louder, higher pitched whistle than before.
really weird.
I wouldn't worry, i helped install a front mount on my mates supra and was boost at liek 18psi when one of the hoses blew off. The car stalled and the lights even went out :( but all was good jsut some P's and Q's on the side of teh raod at night trying to get the F#&$^er back on!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
