I have blown 2, one was the driver's side clamp had gradually become looser and the pipe came out, once i got it back in & tightened them they were fine. The 2nd was last week, but this was the one from the turbo that was a real bastard to get back in. Got it back in and since then the car has decided it wants to boost up to 14 or 15psi*, changing the mbc has no effect either so I'm wondering what the hell is going on. My car is at the workshop all day tomorrow for some finsihing off work & heatproofing, and one of the things is the boost control function of the wolf so hopefully everything will sort itself!
* While this sounds good, if I held it, maybe it will go higher than that, but my engine is standard & the bulk power from the turbo would make it go "pop". 13psi is in my sig, but I run 12 to make sure everything stays alive.
cheers duncan - I would have if I read your post !!
But I took it to bd4s few days back and running really well now.
quite a few issues with the pipes, all good now :)
still wondering if I should go a FM :P
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
