Item: Nissan Skyline R33 Series II
Website: ??
Item Condition: Great Condition - cept for some minor dents (see description)
Reason for Selling: Family commitments, purchasing house. :P
Price and Payment Conditions: $19,000 ($18,500 without monitor and DVD).
Extra Info: Buying house and stuff. Must sell urgently !
Viper 3 Way Immobilising alarm system (with cool Viper flashing window thingy)
Greddy Plenum
Q45 Infinity Throttle Body
Apexi 260deg Cams
Apexi AX53B70 Turbo
Apexi GT Spec Intercooler with all custom stainless steel piping
Apexi Radiator Cap
Apexi Power FC (with Handcontroller)
Apexi Pen Timer (Ltd Black Edition)
Apexi 60mm Boost Gauge
Z32 Air Flow Meter
OS Geiken Twin Plate Clutch
Greddy Catch Can
3-3.5" Turbo Back Exhaust
Nismo 550cc Injectors
Nismo Fuel Pressure Reg
HKS SSQ Race Bov (good for 3 bar)
Bosch 040 Fuel Pump
Nismo Shift Knob
Bride Brix Black Drivers Seat on Bride Rails (Super Low)
Nardi Steering Wheel (Flat Bottom)
Blitz Spec S EBC
Strut Braces front and rear
GAB Height/Damper adjustable suspension
Sparco NR-1 Black 17" Alloys (8" Front (235/40/R17), 9" Rear (255/35/R17)) New tyres - plenty of tread
R33 GTR Cluster (carbon Fibre surround)
All windows tinted in Midnight Express Tint in January 2006.
Car made 325.1hp (242kw) at the wheels tuned by Mercury Motorsports.
Car is clean all over, 3 small dents in the passengers door and bonnet is slightly bent (new bonnet will come with vehicle).
2x HKS Gauges (ex temp and fuel pressure) will come with the car not fitted.
Always serviced every 5,000 kms using Castrol Synthetic R oils (Edge now).
I've owned the car since importing it into the country and have done all of the modifications to the vehicle.
I am located in Rockhampton Queensland and I will be able to post more pics as requested.
Car is VERY drivable, boosts nice and low, and gives power right through the rev range.
Gonna be sad to see her go actually :D
Note: I will NOT swap for anything less + cash. I am not a car yard. The ONLY thing I will consider swapping with is a clean VY Commodore (family, yes).
Please note: Stereo will NOT include the Headunit as this alone is worth $800.
Edited by Phat6
https://www.sau.com.au/forums/topic/120898-r33-series-2-modified-sold/
Pretty sure you wouldn't be interested but would you consider a swap to a less modded s1 gts plus cash??
Also, do you have any interior shots- particularly of the gtr cluster- off topic but how did you get it to work on the gts since they apparenlty need recalibrating cos gtrs have a different diff ratio to gts.
Hello,
Nah, I wouldn't be interested in a swap ... sorry man ...
The GTR cluster was in it from Japan - so yeah ... I know it's accurate, cos the hand controller is reading the same as the needle :)
I'll see what I can do for a photo today ...
Edited by Phat6
Hi guys, it's my first post here, but I thought I would help a mate out.
Phat6 is a mate of mine and I can vouch for the quality of this car, very well modded and VERY nice power. No expense has been spared, only the best parts used.
$21,990 is cheap as chips for this car which has had mega $$$ spent on it - grab it while it's cheap!
too true dude this is awesome price for awesome car but maybe its just that most people at sau already own a skyline. Try alternate means of selling if you want to get rid of it.
I've got almost exactly the same setup in my R33. Same turbo, same cooler etc... I can vouch for the meaty midrange torque of this setup! Ultimately driveable on the street, and incredibly responsive! I'm sure whoever picks up this car will NOT be disappointed!
Good luck with the sale mate.
  • 2 months later...
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
