hey guys, before you blast me with "do a search you F%$K" i have done several, and none have done me justice, SO i ask...
im getting my first 32, and have been searching google and other image hosting places (and the forums of course) for hours trying to find pics of different 32 bodykits.
i guess what im asking is, please post any IMAGES of 32 GTS-T's (2 door) that you have with bodykits, and specify what kit it is.
im interested in
- vertex (found a few pics on google, seems to be most popular)
- BN
- Uras
- do-luck (also found one or two pics)
and anything else you guys think is HOT
much appreciated, steve :P
https://www.sau.com.au/forums/topic/120899-32-bodykits/
im interested in
- BN
- Uras
Hey mate check out a site called www.carmate.com they have a fair few of the displays with some good pics..
https://www.sau.com.au/forums/topic/120899-32-bodykits/#findComment-2227549
thanx guys, but i cant seem to find ANY pics of cars with ANYTHING BUT VERTEX. im not guna buy a kit that i have no idea what it looks like, so if you wana save me from buying vertex, please post some pics of other kits on 32's.
thanx guys :blush:
steve
https://www.sau.com.au/forums/topic/120899-32-bodykits/#findComment-2229742
woot thats mad, TOP GUN, that is EXACTLY what i needed :D thanx alot for that, and slo a 31, thanx for the sites, they were great :)
anyone else got some nice pics to post up?
cheers guys, steve :)
ps. hottest 32 EVER. can u pm me the price of those rims or the type etc :laugh:
cheers, steve :)
Edited by KLowN
https://www.sau.com.au/forums/topic/120899-32-bodykits/#findComment-2231156
learning from my grandad whos a panel beater, id say they were sprayed or tinted with the same paint the car was sprayed in. and no theyre not legal, hes done that many and then had to undo them. i guess its just a matter of how much of a f**khead the cop who pulls you over is :(
correct me if im wrong ;)
https://www.sau.com.au/forums/topic/120899-32-bodykits/#findComment-2237820
learning from my grandad whos a panel beater, id say they were sprayed or tinted with the same paint the car was sprayed in. and no theyre not legal, hes done that many and then had to undo them. i guess its just a matter of how much of a f**khead the cop who pulls you over is :D
correct me if im wrong :D
Yeah pretty much, its a laquer type of black tint. U can get them in car shops here in UK.
a friend did it for me who owns a bodyshop.. he is pretty good.
Legal - dont know, i have not been pulled here (touch wood), but as far as i know, a certain percentage of light must be visible when indicator is on. And they are still bright when you switch them on.. so will have to wait and see...
excuse the punn....
https://www.sau.com.au/forums/topic/120899-32-bodykits/#findComment-2240871
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
