i saw the 88 - 89 model prelude the other day with the rear lights replaced with twin circle skyline lights, a gtr front bar, painted in nissan nismo Blue and worst of all wearing GTR badges. God i wish i had a camera. That car should be banned. I saw it in eastern subs of sydney.
Guest cosmo
Originally posted by 88silhouette
g'day boys
was driving to the stations this morning
anyway, drove past a very late 90's integra. and it had a friggin r33 front lookalike!
anyone seen this? its black. looked goddamn terrible. i thought this sorta shit only happened in america!
now you know what i see everyday in America.
Guest cosmo
Originally posted by hippy
cosmo ... its tragic ... the rice has gone so soggy over there ..
I know. :hellpisd:
Sometimes I wonder why I even bother with the import scene. Then I realize that since I have all my teeth, I won't fit in with the domestic crowd.
Eventually I just go online and find some beautiful Silvia's or Skylines. Or my favorite, McKinney Motorsports RB25DET S13. That calms me down. :P
Maybe this is the in thing nowadays.
I remember reading in wheels or motor that several people have payed bulk cash to have a Holden VX rear end transplanted onto the rear end of a VY (Astra lookalikes).
Luckily there is no need to transplant any front or rear end onto a skyline as there is no need to mess with perfection.
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
