Random Engine Knock Reading And Cold Starts
Confirmed, the block was checked for cracks and was found healthy.
By hardsteppa · Posted
Let's keep it concise please; the fellow asked for help, not nonsense terms. R33 steering overhaul torque values are shown here. -
I shouldve mentioned that the engine is near being complete. I double checked with my mechanic but im pretty sure the machine shop did all the nessecary checks on the block. i also won’t be driving on 800 all the doing doong pulls. Mainly be driving and cruising with friends on low boost maps occasionally opening everything it’s got.
Should be close enough. Noting that 88Nm is equivalent to 2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there.
Cant find a torque spec in the R32 gtr manual But there is one in the silvia manual Not sure if it's the same
