hey guys, ive recently bought a pair of kicker splits and would like to know if any1 has done a DIY to their r33, in regards to installing them to the front doors. I havent attempted to take the door apart yet as im worried about breaking/pulling something apart particularly the drivers door. This is just the first step and Im alredy afraid to attempt it, also Im unsure of where to place tweeters one door is apart. Any help would be much appreciated.
dooky.
https://www.sau.com.au/forums/topic/12095-installing-component-speakers/
Recently bought an r33 and have done much that
Doors not too much of a drama to take off, have 3 or 4 screws around the base, a small screw in the armrest handle well covered (normally) by a cap that flicks out, and the handle cover itself (flick out, slide toward the back of the door)
Then comes the fun part of easing the panel off. Helps if you pull out the armrest handle inset (the little cuppy thing) but its not entirely easy to do (or im doing it wrong) The armrest controls have a cable that clips in/out, unclip it and you're done.
Ive mounted in Sony 6"s with a tweeter up on the backplate to the side mirror. Once the door panel is off it just pops out. Had the best sound result for me, but play around with it once you have the main speaker in for best result. Everyone's head is in a different spot.
Hope it helps
  • 1 year later...
  • 3 weeks later...
  • 2 years later...
Just wanting to know how this went and wether any pics where taken? If so please post
SOMEONE HELP ME GET MY DOOR TRIMS OFF PLEASE....
I have un done the bottom screws along the bottom of the trim, flicked out the cover under the handle and unscrewed the large gold screw, and I have un screwed the pocket in the side door.
Only thing i think is left to do is remove the door unlock/lock handle surround, which i cannot get out and i am scared to break it HELP ASAP
Take a butter knife (or similar) wrap a piece of cloth around it, and just lever it around the surround. There is just one clip you need to find and unclip to get it off.
Even if you just move the knife around you'll find it.
  • 1 month later...
That handle surround CAN break, but just don't bend it too much, and eventually it'll come off. That's the only hard part of the whole damn job!
The doorskin hangs on the sill, so pull the bottom away from the door, then slide the whole thing up, off the sill.
  • 1 month later...
so that's 4 gold screws on pass. side (1*pocket-handle, 1*door lock trim & 2*horizontal door handle)
2 gold screws on drv. side (1 *pocket-handle, 1*door lock trim)
3 black screws on bottom of door trims both sides
take off lock surrounds
take out all switches plus their surroundings
take out pocket-handles (careful)
take out clarion paper poo and replace
good fun :)
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
