G'day, have my pride and joy for sale (copied from my car sales ad:P )
Reason for selling as have new job which requires a new car and very little time at home. Car was imported last year before the rules were changed. Have reciepts for work done in the past year (since being in Aust). Car has, EXEDY Heavy duty clutch and lightened flywheel (5000kms), Hybrid front mount copy intercooler kit (600x300x76), Greddy boost gauge, turbo timer and 5izgen cat-back exhaust (legal noise). The only mod being done since it's arrival in Aust is the front mount and clutch/flywheel. No rust, no leaks. Recently had full fuel clean including, new tank, flushed lines, reconditioned standard injectors and flushed fuel rail, new water pump, new turbo gaskets, rocker covers/oil sump resealed, new exhaust studs, flushed turbo coolant lines, Turbo inspected (running standard boost), new spark plugs, new battery (7 months) engine/clutch fan swapped for 12" and 10" thermo fans. This is a good example of a '32 Type M ready for modifications, very regrettable sale as I purchased this vehicle for modifying but need to move on to a new vehicle. First to see will buy, price is negotiable, feel free to inspect only if prepared to buy.
More info includes 106,000km, autometer oil pressure gauge.
Known problems: thermo fans are running through a manual switch in the cabin, so it needs to be re wired through the relay box/radiator switch to work like real thermos and come on when it reaches certain temps, the reason for this is that I simply installed them as a temporary job but have not got around to re-wiring it correctly
Needs a steering wheel cover
Paint isn't the best, its slightly faded and cracked in some places, but not by much i'm just fussy :ermm:
I am disappointed with having to sell this car (like all my other things:P ) but I need to move on to a new car and new location for my new job
Car is located at Gorokan (Central Coast, NSW). Contact via PM or call 0413292734
Looking for around the 10,900 ono offer mark. Open to offers just send me a PM
Cheers,
Dean
Edited by GTAHH
https://www.sau.com.au/forums/topic/121016-r32-gts-t-type-m-89/
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
