Hey guys,
Yes, yet another front bar question.....anyway.
Has anyone ever seen these lights actually working on a R33 before. I'm talkin about the little white lights on the inside of the idicators. I know there is wiring going to the whole light unit but I just wanna know if they can be used or if someone has seen them working on another R33?
https://www.sau.com.au/forums/topic/121044-r33-m-spec-front-bar-parking-lights/
good question.
mine dont work.
although i am missing the FOG LIGHT relay in my engine bay fusebox.
Could that be why?
When i switch on my parkers (low) lights, the dim lights in the headlights turn on, but no others.
Yeah i wired mine up on my first R33...
I bought a series 2 indercator stalk and wired the relay to the fog light switch on the S2 stalk.
Easy done... Didnt do anything really...
Series 2 front bar with fog lamps is a far better idea.
Actually, i found another thread that explains all this.
R33 S1 had fogs as an option. S2 came standard (i think).
So there are actually no lights in there, just a clear lense. This explains why i have no FOG relay.
Are the fog lights like parking lights (dim) ?
Or like spotties?
I have a pair of spotties on my front bar. Bright as hell. I think they look ok.
Wouldnt bother with the standard fogs, especially for the extra hassle of installing bulbs etc.
Hey, those look alright Munkyb0y, have ya got a pic with the fog lights on?
They might just be the answer to my lighting problems. :)
I'll post a pic soon. Havent got one right now.
These lights are really bright, like high beam+ bright.
I put bulbs into the standard assembly. I just used a parker bulb 5W. If you use anything bigger you will melt the lamp assemby. They simply were not made for fog lamps like the Series 2.
Does not really matter cause fog lamps are only surposed to be used in high beam conditions.
Here's a pic with the lights on.
It's an old pic, havent had time to take another one at night.
These lights are very bright, and only meant for high beam use, as Col-GTSX said.
They have led's in them too. And a switch box under the dash to change the colours.
Nice novelty, but I dont use it, they were on the car when i got it.
by the way, these arent my real plates, duh!
They look pretty good mate.
Only problem is, finding a spot for them in my front bar without blocking the fmic.
I wish i had that problem. :(
Your bar looks pretty damn nice.
It's kinda similar to mine, sorta, but doesnt look quite as low.
Do you have issues with driveways and speed humps etc?
Mine's way too low. Got stuck in a carpark the other day, exit ramp was too steep, had to go out the entry ramp. :D
What type of bar is yours?
Been looking at changing mine.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
