Hey guys,
Yes, yet another front bar question.....anyway.
Has anyone ever seen these lights actually working on a R33 before. I'm talkin about the little white lights on the inside of the idicators. I know there is wiring going to the whole light unit but I just wanna know if they can be used or if someone has seen them working on another R33?
https://www.sau.com.au/forums/topic/121044-r33-m-spec-front-bar-parking-lights/
good question.
mine dont work.
although i am missing the FOG LIGHT relay in my engine bay fusebox.
Could that be why?
When i switch on my parkers (low) lights, the dim lights in the headlights turn on, but no others.
Yeah i wired mine up on my first R33...
I bought a series 2 indercator stalk and wired the relay to the fog light switch on the S2 stalk.
Easy done... Didnt do anything really...
Series 2 front bar with fog lamps is a far better idea.
Actually, i found another thread that explains all this.
R33 S1 had fogs as an option. S2 came standard (i think).
So there are actually no lights in there, just a clear lense. This explains why i have no FOG relay.
Are the fog lights like parking lights (dim) ?
Or like spotties?
I have a pair of spotties on my front bar. Bright as hell. I think they look ok.
Wouldnt bother with the standard fogs, especially for the extra hassle of installing bulbs etc.
Hey, those look alright Munkyb0y, have ya got a pic with the fog lights on?
They might just be the answer to my lighting problems. :)
I'll post a pic soon. Havent got one right now.
These lights are really bright, like high beam+ bright.
I put bulbs into the standard assembly. I just used a parker bulb 5W. If you use anything bigger you will melt the lamp assemby. They simply were not made for fog lamps like the Series 2.
Does not really matter cause fog lamps are only surposed to be used in high beam conditions.
Here's a pic with the lights on.
It's an old pic, havent had time to take another one at night.
These lights are very bright, and only meant for high beam use, as Col-GTSX said.
They have led's in them too. And a switch box under the dash to change the colours.
Nice novelty, but I dont use it, they were on the car when i got it.
by the way, these arent my real plates, duh!
They look pretty good mate.
Only problem is, finding a spot for them in my front bar without blocking the fmic.
I wish i had that problem. :(
Your bar looks pretty damn nice.
It's kinda similar to mine, sorta, but doesnt look quite as low.
Do you have issues with driveways and speed humps etc?
Mine's way too low. Got stuck in a carpark the other day, exit ramp was too steep, had to go out the entry ramp. :D
What type of bar is yours?
Been looking at changing mine.
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
