  3lit3 32 said:
Get over it dude.
I edited the post to say *oops double post again* cost i f**ked up and posted twice.
I'm over it though, thanks for your support man. It was a tough time, big brother chick with fake titties was a struggle for the old concentration to stay on the forum.
  • Replies 47
  r32 gts-turbo said:
thanks for taking the time to right all that hakai, your a legend mate, ill check that out as well :)
Um where abouts is the fuel filter on these things?
No problem at all :)
I have no idea where the fuel filter is, never changed one in a skyline so it'll be a first for me too. I'll do a bit of looking around tonight and see what I can find if I get time.
Good luck with the coils/plugs.
Just a note about taping the coils though, on my coils I noticed that the brace that bolts them to the coil rail is solid and runs around the entire pack, not like in that guide to taping them, those are R33 coils which I believe are a bit different, they only have screw holes at each corner or maybe that's just his?
Mine have the band running all the way around which makes it a bit tedious to tape the top and bottom, I haven't inspected the bottom of my packs since I taped them because I am too lazy to take them out, but literally one drive after taping them the heat seems to have melted the glue on the tape and the top part has just shrunk and pulled itself off the coilpacks. Not sure if this will happen on the underside, I'll find out when I get unlazy for a few minutes lol.
Good luck mate :)
Ben.
  Cubes said:
Yep so you have experienced it clean up over 6k?
My experience wasn't the same, they simply crapped out and stayed crapped out big time. :laugh:
I have. The car would be shocking from about 3.5-4.5k and then pull to redline like you wouldn't beleive. I didn't think it was coils either, so i played with the tune and sometimes it would drive perfectly (usually only a quick fang up the street to get an af reading, followed shortly after by a quick test drive) and other times it was a bucket of crap (drive to work).
side note, mine does that. When i just start it it seems fine accelerating but once it warms up or ive been driving it a while it starts screwin it. Taking it to ultratune tonight, will pay for machine hire for diagnosis but thats about it. Anything spark related is to dam tiring to get to
Edited by r32 gts-turbo
thanks for the help and thx GTST for the diagram, your a legend.
Took it to a guy we know and he did an assessment for $60. Unfortunately this didnt include spark assessment but. he found fuel flow to be very low and pressure to be about a quarter of what it should be. Also my VAC was slightly low (no idea) and he thinks that when they replaced my timing belt they miss adjusted it by a gear. Also a possible MAF sensor fault.
What do you guys think? truthfulness, how much they would effect me, would they effect me in the way i described, is it still likely to be spark issues
ill try change the fuel filter (if it looks shoddy or clogged) tomorrow and see if that helps, otherwise if you guys reckon pump is a likely cause and that the guys not just being dodgey, ill probably just get a standard pump, as it should be sufficient to hold the 33 turbo im putting on soon.
thx
ok cool thanks dude, you think the standard pump is good enough? ive been seeing recond ones for about $120 i think ( or im tripping) and the gtr ones for $250 (tripping?) and although im upgrading turbo id be tempted to stick with the standard 1
Why do you suggest going with a 040 or 044? I was looking at the 040 and they go for about $230. A stock r32 one recond (or new?) is worth like $120 according to a mechanic or 2 i know and will be easily enough to run 14 psi on a 33 turbo with minor mods wouldnt it? From what i read the standard pumps are good for 300 bhp and id be getting like 220 max with those mods methinks
thx :(
Why would you bother going with another R32 pump or a recond one, when like you said for another $100 or so you can get a pump that is easily capable of handling that power, plus you know it won't crap out straight away, plus leaves room for more power upgrades in the future?
You may very well be able to support those mods and power from an R32 unit, but wy risk it? Better to go for a bit of overkill when it comes to fueling.
Completely up to you though, just what i'd do though.
FYI on ebay they range in price from $160 to $220 for a 040
http://search.ebay.com.au/search/search.dl...tle22=bosch+040
$215: http://www.skylinesaustralia.com/forums/in...110033&hl=bosch
$200: http://www.skylinesaustralia.com/forums/in...119912&hl=bosch
$275 for a 044: http://www.skylinesaustralia.com/forums/in...118625&hl=bosch
$179 Walbro: http://www.skylinesaustralia.com/forums/in...83622&hl=walbro
Edited by insu
ohhh thats cheaper than i thought, saw the price of $230 in one of the trader pages on this forum, thx for all the research to :( Ill have a look at the walbro or the 040's on ebay. Im assuming the walbros and the 040's dont need any mod'ing to fit on, ive seen some pictures they look easy enough, assuming you dont need ecu retuned to cope with it (maybe a reset) or a new fuel pressur regulator? Just cut some crap off the mounting brackets right? Alot of people seem to be having problems with the walbro's leaning out so ill avoid them and go the 040, what model number should i look at? all 040's are the same? can you get a Aftermarket mounting kit for 040's?
You'll find that the problem with the walbro's seem to be that they are designed to flow their max amount at a voltage higher than that of the standard wiring loom.
If you sort that problem out, they should be good.
There isn't really that much you have to do to get them to fit, but you will need to do things like, replace the pick-up sleeve, lines from the sleeve to the pump, wiring, making the unit fit the bracket properly etc.
Alot of people seem to disregard the ecu controlled downstep in voltage on idle to reduce the amount of flow the pumps produce when idling, and just wire the pump straight in.
Check it out man, search button's you friend!: http://www.skylinesaustralia.com/forums/in...=67683&hl=bosch
hey ive already had a look at the diy on self installation and a couple of other topics on pumps, sucks that so much changing is needed i guess ill go with one of the tomei ones that doesnt require any editing
just thought id update this because it might be helpful to some one some where. Mechanic had a look told me i had bad flow bad pressure, so i replaced the filter and got him to chuck a walbro in for me ($300 all up, with a crazy pump price). Car is a helluva lot faster than it has ever been, even before the misfiring, when i had it running 12 psi. It has absolutely no splutters or anything like that, even droping it into 2nd from 1st @7k rpm nothing. Really rams u into your seat accelerating in 2nd (never had it happen before) and had absolutely no flat spot or power loss all the way to 6.2k, it kept moving didnt slow up at all like lots of people say happens rb20's, due to the turboes capabilities. So yeh my cars finally working and its maddd :(
Edit - 2 weeks later problem is back hehe
  • 3 weeks later...
Really? Is the problem back?
I have had similar problems, and were initially solved by splitfire coil packs however, the flat spot is still occuring between certain revs and am in the process this week of installing a walbro pump. Ive been advised by a few mechanics that this will cure it!!
Dont tell me otherwise, hahaha
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
