I am currently running 18psi through my RB20 with a Gt2530 day in and day out, and it runs fine, beautiful actually.
I was wondering what the theoretical boost limits would be for a standard internal RB20, and this model of turbo. Saw some of the guys have been running 21psi, 22psi with similar setups.
Running a Wolf3d v4 and eboost.
The engine's history is fairly uncertain, but it has been running a consistent 18psi for at least the last 2 years, and the car has been drifted and thrashed fairly hard, although it runs fine currently.
On a cold morning it is a bit spluttery and misfirey, but once she is going, runs fine.
Obviously 18psi is not what you would call 'safe' for a reasonably old engine, but would like some advice.
https://www.sau.com.au/forums/topic/121089-highest-safe-boost-on-standard-rb20/
no such thing as "safe boost"
turbos all flow different amounts of air, different motors ingest different amounts
As long as you have a solid tune, and you check the health of the motor before screwing large amounts into it.
It should be fine
By check the health of the motor you don't mean pull the head off and check the head gasket e.t.c. do you? Because thats way too time consuming for my liking.
Obviously all turbos flow different amount of boost... but the fact that the 2530 is a very popular option for the RB20, I assume there are plenty of memebers running 2530 on stock internals, I was looking for some members, from their experience, to tell me what kinda boost they have run on similar setups.
Yeah im running 18 consistently now, was looking to go for something like 21psi when the weather cooled down, which is starting to happen now.
Just wondering whether anyone else consistently runs 20+ through the turbo on stockers...
Might just have to run 21psi on dyno days only?!
have you not read one post in this thread?
Is it just that you have to be involved in every post on the forum because you are a moderator, or do you just like revving people up??
I asked a simple question, so far one of the posts was from someone running substantial boost through the turbo and engine, which is what I want to know. You obviosuly dont have the setup I am talking about...
Which posts is it that I am supposed not to have read R31Nismoid??
Is there 10 posts hiding there saying that someone ran 21psi and blew their engine up, and I just didnt notice them ?? Because thats what I am trying to find out...
he is involved in every post because this is a section that he moderates.. and also he is fairly knoledgble i'd say your biggest risks are tuning.. and yes do the search that sydney kid recommend.. i notice your from townsville i'd be careful with who you get to tune it.. and i cant reccomend anyone from cairns that could tune it safely either as wolf is not highly used up here and the few people that do use it.. i wouldnt trust them tuning my pushbike
as said (already). It is NOT a question of boost. Boost level really is irrelevant in this thread with the mods supplied.
Read my first post, if you dont understand it thats fine, ill be more than happy to explain more.
If the tune is good, the motor is healthy, it will be ok
The Wolf3D was tuned originally by Ricol in sydney with an aggressive tune for about two years, and now it has been tuned by TMS in Townsville. AFR is in the mid-12s to keep it relatively safe. Engine appears to be healthy but obviously havnt done a compression test so not sure.
How much does a compression test cost roughly?! I guess its probably worth it...
hahahaha yeah ive noticed that they dont seem that good up here. Wont be here all that long, prolly move back to Sydney or Brisbane in a year or so...
I am probably more worried about the amount of boost the engine can handle stock, I too have been told that 2530's are able to handle in the vicinity of 25psi, so obivously that isnt the weakest link. The turbo seems fine on face value, it has a nice spool down when I turn the engine off and everything, although thats not exactly a perfect diagnostic tool...
Obviously there have to be a few people that have blown their RB20's ip, what kinda boost did it??
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
