Hey guys just trying to work out whats wrong with a mates RB20. We cant get cylinder 6 (closest to the driver???) to fire. swapped plugs, coil packs. Its not fireing as it makes no difference to the engine rpm and sound if its plugged in or not so its def dropped that las one. The only thing left to do is swap a PTU but mine isnt interchangeable with his. Is there anything else left to check for?????
Would a compression test reveal anything, but surely even if its compression is stuffed then it could be down on power but still fire???
https://www.sau.com.au/forums/topic/121110-lost-a-cylinder/
Definately need to do a comp test. If its way down it wont fire.
My RB20 blew through the head gasket into the water jacket as the water had corroded under the HG to the steel ring and rusted it out from behind on number 6.
The comp was down about 10 PSI from 120 on rest of them but was still firing ok though prior to blowing full pressure into cooling system and blowing an impossible to get at hose out at the Calder Drags.
Whatever it is, it sounds not good.
https://www.sau.com.au/forums/topic/121110-lost-a-cylinder/#findComment-2231055
grab a clean cloth then shove it down the #6 spark plug hole (use a screw driver to push it down if you like). pull it out and check if its just fuel thats in there.
any signs of oil and you've done one of your rings.
check if hes blowing blue smoke which is another sign of damages rings.
https://www.sau.com.au/forums/topic/121110-lost-a-cylinder/#findComment-2231134
Have you pulled the plug and coil out and actually checked for spark whilst its running?
Have you compression checked the cylinder?
Have you connected a noid/led test light to check for injector pulse?
If its all sweet, my guess is a plugged injector and will need replacement. (rare problem though and im sure you will find the fault before you get to this stage)
https://www.sau.com.au/forums/topic/121110-lost-a-cylinder/#findComment-2232874
Yeah my friend got well electricuted when we started the car with the spark plug out, kicked it over anyway. we checked the pulse of injector with the old listening to the screwdriver on the top and it was ticking fine.
So I guess its just down to checking compression and going from there.
Cheers everyone
https://www.sau.com.au/forums/topic/121110-lost-a-cylinder/#findComment-2234284
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
