hey guys,
im after a set of insulators and O rings for the fuel injectors in my gtr.
Im too scared to call nissan up, as i dont wanna sell my kidney's to get the parts.
would a fuel injector place have aftermarket insulators in stock?
thanks
steve
Edited by PHATR32
oooooooookkkkkkkkkkkkkaaaaaaaayyyyyyyy
i just called a "injector speicalist" in balcatta, and he had no idea of what i was talking about. he told me the insulators had to get pressed?? I think he's been breathing too much fuel......
can anyone reccomend me someone who knows what im talking about??
steve
The guy at the injector place is right. The insulator pressed onto the injector and its black if i remember. Why do you need 12 when there is only 6 injectors or do you mean 6 insulators and 6 orings.
I would ring that injector place back and take them down there so they can have a look.
' date='8 Jun 2006, 12:08 AM' post='2237932']
when i went to nissan i got o-rings.. 2size one big, one smaller
thats all i needed for my nismo injectors
Thats probly cuase you have side feed injectors. The gtr has top feed, and it uses only 1 O ring, and 2 insulators to basically hold it in place.
I just rechecked my injectors and i actually need only the bottom insulator.
Steve
Ok now i know what you mean. Its the black rubber grommet that sits in the head.
I would still go to an injector place or you are goin to have go to nissan to get them.
I work for nissan but im on workers comp now so im unable to help dude. sorry
yeah no worries man.
i might pull the injectors out sat morning, and take one down.
they look exactly the same as the ones in my old laser, although the sizes might be differant.
Im sure i can find them for cheaper else where, after all, it is a small rubber ring.
steve
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
