f**k me.
i called nissan up again to double check the price, just incase i misheard.
Prices are:
Bottom insulator: $14.90 EACH!!
Top insulator: $6.00 EACH!!
O Rings: $14.90 EACH!!
That come to a grand total of $214.80 for less than 100grams of rubber.
steve
i got my injectors cleaned, flow tested, leak tested, spray pattern test, new pintle tips, new o rings, new insulators the works
23-24$ an injector, he comes to your house, Southside injection, takes about 1hr, maybe give him a ring? he just asked me if they were high or low impediance , top or side feed and then he came around :), excellent service
Hey dude..
I have the top 'insulators' and o-rings laying around here from a set of GTR injectors i bought and then put into my RB30. The VL/VLT/R31 top o-rings dont exist as such since they are a hose tail type. The bottom ones (not the pintle caps tho) are the same as far as i could tell nad the GTR injectors went straight in.
If you want them you can have em, they are no use to me. Dunno how old they are but are meant to be off an R33 GTR. Drop me a PM.
Brent.
theyve been found! for $1 each!!
i went to an injector place and the dude could match them for me (1mm too small) so i was driving past Odin part in balcatta and thought (why not) so went in there they had some!!
Although they were about 1mm bigger, it didnt matter. they fitted in perfectly, nice and tight!
cost me 95cents each.
bad news is i found an injector thats leaking from the body, so i need a new one.
steve
I went through pretty much the same thing Steve. After stuffing around with rails, insulators, o-rings etc closer inspection turned out to be the injector itself leaking (well two of them really). A set of 700cc sard injectors and no more dramas.
Ryan.
' date='8 Jun 2006, 12:08 AM' post='2237932']
when i went to nissan i got o-rings.. 2size one big, one smaller
thats all i needed for my nismo injectors
So the injectors didnt come with O-rings?...I am getting Nismo jectors soon
Damn, means I have to fork out more unexpected money :no:
And yeah if that question was asked of me it was quite obvious to see that the front injector was leaking even at idle and fuel was running down the side of the block and dripping off the sump. Not a particularly fuel efficient or safe vehicle in that state :)
not only that, my injectors tap like freaking crazy!
i dont have a zorst, so my car is pretty quiet. all you can hear is the injectors clacking away, and the timing wining its ass off.
upgrades injectors are on the list, but not at the top unfortunetly.
steve
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
