the airflow meter maximum amount of airflow it can show the ecu.
0% is no airflow currently going through and 100% is the maximum amount of airflow the meter can show to the ECU. its a 0.00v to 5.00v scale, with 5.10v being the absolute max
Fancy that i just discovered that lastnight on me SAFC aswell. Interesting little tool there.
Flat to the floor, 6000rpm was reading about 75% - got pleanty more mods to go till i would need to bother with a larger AFM.
if you are maxing out the stock afm and want to upgrade perhaps its about time you consider a stand alone engine management ecu instead of piggybacking on the stocker. theres a world of great tunability locked into a stand alone ecu that you can't achieve with the safc.
400 load points to tune >_<
I've tuned around 90 of mine and the car feels fantastic and is good on fuel economy too
^ Damn you PowerFC people, i shoulda bought one instead of the SAFC2 >_<
Nah for the moment it should be sweet, does its job fine. I cant really justify spending so much more when i know im gonna be using the stock turbo for a while.
SAFC is good for a basic modded car but not so good for masive mods etc but I have seen a an safc series 1 running larger injectors for a bigger turbo on a VR4 Galant and it didn't do a too bad of job. Got it into the 12's.
So it can be ok but a stand alone power fc is by far a better chioce.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
