Here you are big fella.
Althought these prices are not the "brand new price" if you were thinking of selling or buying for that matter here is a rough guide.
http://search.carsguide.news.com.au/news/r...dr+Man+5sp+2.5T
All the best
Regards Evan
PS) by the way, nice choice!!!!!
AFAIK, the later skylines were only really a Japanese only model, not sold anywhere else, but only available by importing. but 100 R32 GTR's were sold in australia by nissan, but didnt sell too well. I heard that Kerry Packer bought a few as well?
Edited by edspaged2
what... I thought R32s and R33s were sold here, seeing as they are actually quite a common car.....?
anyone know what they sold for straight from Nissan in Yen?
I'm just curious is all. Not selling or buying anything, only mentioned the GTST 4 door in particular because my Rb25det came out of one.
I think he wants to know how much they were brand new in yen, then convert that yen to AU$.
Like if he was in japan when the first 33's came out, how would he have to pay for one brand new in AU$....
Although currency has changed in value since then.
Edited by KeyMakeR33
I used to have the prices. my computer died.
Keep in mind that prices change - inflation. 93 model 33s are now 13 years old.
remember skyline > 200sx. which were sold in the 40s here.
Skylines common? it's only because you're on the look out for them. e.g. if you were actually looking out for au falcons, you'd see about 10-15 times as many as skylines.
i notice everyone says skylines are common... i personal dont think so. lets take a 1000 cars... out of that thousand how many would be a 32, 33 or 34. not many at all. you never hear someone say, civics are common... preludes are common, 180's are common, silvias are common.
just skylines, maybe because they stand out!!! haha
id hear my friends talk about someone in a silvia or a 180 saying it was "sick" or whatever even though there are a hell of alot of the silvia range (considering s14's and s15's were locally deliverd) but when i bought my r33 most of them turned up there noses and just said.... pffft seen so many of them and didnt even want to look at the car.
na, Skylines are pretty common. I know at least 4 people that own a post R32 Skylines.... And you see at least one a day. IMO, thats what I call common, especially for a car that was never sold here new.
Plus, look how many members this forum has, theres what? 23,000 members.... vast majority are Skyline owners of course.
R32, R33,and R34 Skylines collectively are more common than the modern Monaros. Theres only what, 13,000 of them all up. I'd say theres more than 13,000 post R32 Skylines
but anyways...
Edited by b1ancardi
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
