  • Replies 102
Question for SK to get an Idea for the 2L boys.
Standard Rb20 with normal breathing mods - pod, intercooler, good exhaust, EBC etc.
What rpm does it start boosting?
What boost pressure have you found to be the most efficient to make power?
At that pressure, when does it hit max boost?
I understand that you probably feild questions like this all the time but I know that you run a GCG highflow on your rb20det and am very interested to hear your very knowledgable experience on the all round performance of this engine/turbo combo for a street car and what mods/tricks get the best out of this package?
Understand if you don't want to rewrite essays but any info would be most appreciated!
Keeping it as brief as I can;
Using a GCG Ball Bearing High flowed RB25DET turbo.
We used to run 1.3 bar on the old (170,00 k's) RB20DET for 225 rwkw
In 3rd gear it would make the full 1.3 bar by 3,750 rpm
(that's on the Commander and the Datalogit, the old R32GTST standard tacho read about 10% high)
It would hold the 1.3 bar all the way to 8,250 rpm (rev limiter)
Mods were a Power FC with boost control kit, POD, heat shield, ambient air feed, Jun adj cam pulleys (inlet and exhaust), Performance Metalcraft spilt dump, standard R32GTR intercooler, R32GTR fuel pump, R32GTR injectors and a light weight OS Giken twin plate clutch
Tuned for response, in particular we spent a lot of time tuning the ignition timing between 3,000 rpm and 6,000 rpm. Plus I sacrificed a little max power for more response using the adjustable camshaft pulleys.
I have compared a number of high flowed RB20DET turbos with RB25DET turbos and I can't say as I have noticed any difference in the external sizes of the compressor or turbine covers. The R34GTT turbine cover is slightly larger of course. My understanding is that the internal dimensions of the RB20DET turbine cover are slightly smaller than the RB25DET turbine cover. But that is machined to the same size when GCG do the high flow anyway.
:D cheers :(
Hey guys,
Would I have to retune the Power FC if I get this turbo?
Is there a difference between the rb25 turbo in the series 1 & 2 R33?
I have a series 2 turbo on my RB20 so it would be a straight swap right?
Hey guys,
1. Would I have to retune the Power FC if I get this turbo?
2. Is there a difference between the rb25 turbo in the series 1 & 2 R33?
3. I have a series 2 turbo on my RB20 so it would be a straight swap right?
Suggestions follow;
1. Yep
2. Not after it's high flowed
3.Yep
:) cheers :dry:
Edited by Sydneykid
Hey Gary
If you ever have anyone looking to high flow an r34 turbo (with the larger rear housing), but the turbo is still on their car and they want to do the swap on and off in one day, I have a blown one.
I'd be willing to let them have that highflowed in exchange for a working on. They'll get the same result anyways :)
Hey Gary. Did you have a dyno sheet you could put up for your R32 setup?
If I had the supporting mods with an ECU remap and a JayCar boost controller instead of the PFC and associated boost controller would I theoretically achieve similar results?
Cheers in advance
EDIT: did you have cams with the adj. cam pulleys?
Edited by ellie
Cheers in advance
Sorry, I don't have a dyno sheet that I can post up for the R32GTST with the RB20DET in it.
There are limits to the ECU remapping, you might run into them before you get to the target power output. Every car is different, I can't be more specific than that.
Cams is an interesting story, I was given what I was told where standard R32GTR cams. I had no reason to check them. There wasn't any reason for me not to believe the guy that gave them to me as he had no motive to do otherwise. I stuck them in at the same time as I did the turbo and the Power FC install. Tuned it and away we went, used the old RB20 for couple of years. Then I stuck the original RB30DET into the R32GTST and gave the cams back to the guy that loaned them to me. It wasn't until I tried to copy the R32GTR cams into RB20 trick for someone else that I ran into problems, same as a few other guys have.
So I don't know whether it made the power on standard RB20 cams, RB20 aftermarket cams, standard RB26 cams or maybe even aftermarket RB26 cams. When I sold the original RB30, I stuck the RB20 back into the R32GTST with its original cams. It made within 8 rwkw of the same power, which I wasn't surprised at given its age, it was getting pretty tired at 180,000k's and after 3 years of racing.
Not a very conclusive answer I know.
:D cheers :D
Cheers in advance
You will find it very very difficult to get full boost (1bar or more?) on before 4k as Sk has, however 300rwhp can be achieved with standard cams and no cam gears, with these items you can bring boost on earlier (more cams..) and gain more hp obviously too! I am going to go down the cam's track abit later for some more responce but have no idea on what cams to use as i havn't look at that yet
Edited by jazza08
hey do you know if you can purchase the internals or rebuild kit from gcg and then rebuild the turbo yourself? I've pulled apart a saab turbo before and re-assembled it. wasnt really that hard
My understanding is the rotating assembly, once mounted in the core, needs to be balanced on a fairly expensive (and highly accurate considering 150,000 rpm ) piece of machinery. From there on it’s a simple bolt on job for the compressor and turbine covers which have been machined to match the compressor and turbine. So not much time (money) to be saved as their is very little DIY.
:P cheers :(
well worth your money alphinestar? i noticed in your signiture youv got heaps done to your car but 261rwhp isnt a whole lot? i dont understand.
I was wondering if this group buy is still available. I think today I blew the turbo, I was driving along gassed it then heard a loud pop followed by a big cloud of white smoke and no boost, a mate thinks it may not be the turbo but engine related. my guess is Ive over boosted. recorded 1 bar on the ebc .
sk,
When are you going to be running a GB for the R34 Neo Turbo's? as i have a blown r34 turbo that i want to get highflowed instead of my r33 one!
Cheers
Send me the R34GTT turbo and it will be done. PM sent.
:happy: Cheers :)
261rwhp was with my old turbo with blown seal
ill give an update on thursday when i get the retune hope i can get 300 with stock injectors
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
