Well, I understand you want this information, but you need to understand the difference between a group buy and a sales thread.
Here, SK is not making any money, he is simply supplying a product at a discounted price to multiple people at once. Its assumed that people that get involved in group buys know what they are buying and therefore just find it at a better price being in a group (economies of scale purchasing).
On the other hand, in a sales thread, the sales person is trying to sell the product. Therefore he needs to know all the information about the product etc to actually sell it to the customer.
As above, call GCG or have a look on their website www.gcg.com.au. Specifically, here http://www.gcg.com.au/Catalogue_Menus/Upgr...pgrade_gtst.htm
  • Replies 102
ok so gcg normaly charge 1950 to hi flow your turbo, but this group nuy offers tge same service 300 cheaper.
the website says these are rated at 450hp, and this thread say capable of 265 rwkw?
is 450 hp the engine figure?
450 bhp = 336 kw – 70 kw for drivetrain and roller losses (Dyno Dynamics) = 266 rwkw
:glare: cheers :laugh:
  • 3 weeks later...
Just asking the question as the car is paid off in the next fortnight so its time to look at what to do next.
How does it go for RB20s? I would be guessing same as NEO RB25s? Then what if I wanted an RB25 turbo for the extra size? Could I do that?
People who have installed them have said they are a lot more laggy than stock but when they come on, its like BOOM.
Ive been told they hit full boost around the 3500 mark compared to an RB25 where it still hits around 2750 or so.
To me, the top end is where its at as long as it doesnt hit FB at like 5000 rpm like a massive laggy bitch turbo does.
Keep in mind that Alex hasn't done any tuning. You can usually pick up around 250 rpm earlier boosting with tuning.
:) cheers ;)
Hey gary
thought i might be able to save you some time. GCG offer a 10% discount to sau members, which works out to be about 1750 anyways.
Cheers
Yep, I know, but not all of the guys on the forum are members. Plus the Group Buy includes all of the necessary gaskets and seals plus delivery to anywhere. So it's a little cheaper.
:P cheers :D
Edited by Sydneykid
1. How does it go for RB20s?
2. I would be guessing same as NEO RB25s?
3. Then what if I wanted an RB25 turbo for the extra size?
4. Could I do that?
Sorry I missed this post. Suggestions follow;
1. Same as Neo
2. Yes
3. There is zero difference between the RB20 turbo high flowed and the RB25 turbo high flowed. I wouldn't bother.
4. Yes, but refer to above
;) Cheers :D
Edited by Sydneykid
Definatly feel the upgrade over a stock.
Untuned my Stagea had 160awkw through an auto with 14psi, no tune what so ever and a full exhaust. (compared to a stock 115-120awkw)
So the Hiflow turbos off an RB20 will fit an R34 NEO engine Gary?
Yep. Obviously it would be slightly better (for max power) if you used the R34GTT turbine cover when the high flowing was done.
:D Cheers :nyaanyaa:
Question for SK to get an Idea for the 2L boys.
Standard Rb20 with normal breathing mods - pod, intercooler, good exhaust, EBC etc.
What rpm does it start boosting?
What boost pressure have you found to be the most efficient to make power?
At that pressure, when does it hit max boost?
I understand that you probably feild questions like this all the time but I know that you run a GCG highflow on your rb20det and am very interested to hear your very knowledgable experience on the all round performance of this engine/turbo combo for a street car and what mods/tricks get the best out of this package?
Understand if you don't want to rewrite essays but any info would be most appreciated!
put this turbo on the car on the weekend and its bloody awesome boost comes on hard and car easily boost to 16psi on stock acuator give thumbs up for this turbo :)
Ok remembering my GCG Hi-flow was based on an rb25 turbo (bigger turbine housing than rb20).
You will get the turbo spooling around 3000rpm and expect full boost between 4200-4500rpm with a good elc boost controller (full boost being around 15psi), my turbo will hit 20psi at around 4800rpm but has external gate (internal welded up due to an uncommon creep problem) which actually made it slightly laggier for some odd reason!
My turbo made 300rwhp on 20psi, remembering it doesnt need those boost levels on an rb25 to make more power (bastards... lol) but the rb20 needs the higher rpm's and boost levels on the turbo.
With some cam's i believe you can get the boost on quiet abit earlier! And with an rb20 turbine housing that little bit earlier again. Its a great turbo for the street, it does suit an rb25 better but i have no problems with the lag on the old rb20 :(
Now Andrew you better come on the cruise on antilag on friday for tests! We need a driving comparison for the hi-flow performance on an r32 rb20 against an r33 rb25 with more power n more weight! :D
Guest
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
