  • Replies 102
Any one have Gary’s mobile number? would be much appreciated...
Thanks
Lee
Another PM reply sent. I reply to EVERY single PM, eventually. I get 30 or so PM's every day, so obviously I can't reply instantly to every one.
:P cheers :D
Have they sent me the turbo yet??.....
Tried to send PM but your inbox ful :laugh:
:thumbsup::laugh: 5 weeks now with out a car.......
:laugh: Gary.......
please keep me up to date...
thanks
Lee
Tried to send PM but your inbox ful :(
:D:D 5 weeks now with out a car.......
:O Gary.......
thanks
Lee
Hi Lee, sorry that the PM inbox was full, I received more than 100 PM's over the weekend. The turbo for high flowing had a cracked turbine cover. I have been searching for a replacement, success today, one is one its way to GCG.
:( cheers :D
:P cheers :)
SWEET AS!!
thanks for the update Gary...
When do you plan a NEO GP buy?
Do you have any info on the NEO Turbo?
Does it come on boost earlier, later or the same as stock?
Std NEO has nice low down torque & am not real keen on loosing that.
I don't have a Neo turbo to exchange, if you can find me one for a decent price, then I will organise the Group Buy.
The Neo turbo has a larger turbine cover (same compressor) as the RB25DET (non Neo). Hence it is slightly slower to build boost, but it gives around 10 rwkw more max power.
My R34GTT had more power everywhere (idle to redline) with the GCG ball bearing high flow on it than when it was stock standard, That was with 98 ron fuel, using 100 ron fuel would improve that even more because I can add a fair bit more ignition advance.
I tuned an R34GTT with a GT30 last week and improved the 1 bar boost from 4,500 rpm to 3,800 rpm. So, as usual, it comes down to tuning.
:) cheers :O
Thanks for the info, are there any disadvantages with hi-flowing compared to changing turbo outright?
Seems to be some varing opinions on hi-flowing.
The big advantages of a GCG ball bearing high flow;
1. Fits back on exactly as it came off, you don't have to make parts, buy parts or pay for parts. All the necessary gaskets and seals come with the turbo. Pay $1750 and that's it, fit it and tune for it.
2. The result is well known, stick some cams with the high flow, decent FMIC, injectors, fuel pump and 3" exhaust and you will get 265 rwkw if it is tuned correctly
3. More power than standard everywhere, that's from idle to redline. You have to be very good at choosing turbos to duplicate that.
4. Legal, not defects for fitting a high flow, looks exactly the same as a standard turbo.
5. It's a ball bearing water cooled core (not a plain bearing, oil cooled core).
The advantages of an aftermarket (replacement turbo);
1. Any power output you like, trade off response and lag to max power to whatever level you want
2. All price ranges, plain bearing oil cooled turbos are cheaper than high flows
3. Cheap, second hand turbos are always available
4. High mount, external wastegate whatever you want/can afford
5. No guaranteed result, if you choose right you will get a good result, if you choose wrong you won't
As they say horses for courses, if you are after a simple bolt, legal, no more to do solution and your power target is up to 265 rwkw then you can't beat a high flow.
:( cheers :no:
Hmmm, thanks for info! Might have to start takin' the wife out for tea! :(
Did the $1750 include feight there & back or just back or no freight included?
Hmmm, thanks for info! Might have to start takin' the wife out for tea! :blink:
Freight is included
>_< cheers :happy:
:( PM Sent
EDIT!!
In box full.......
so i'll just post here......
Any Updates Gary!!!
Man... 6 weeks and counting.....
he he he you said a week in orginal post....
hmmm... being patient but 6 weeks is still a very long time......
sorry to keep bugging you but i hope you know what i'm feelin here.
Oh well... Waiting on your reply...
Thanks
LEE
PM Sent, I am sorry for the protracted delay. There are 2 turbos in the exchange program, one hasn’t come back for 6 weeks. The guy hasn’t removed the exchange turbo from the car yet and he already has the high flow. This has taken one turbo out of the rotation.
Unfortunately the other turbo that came back on exchange had a problem. It had a cracked turbine cover and I have been searching for a replacement for 4 weeks. I finally found one yesterday and GCG did the machining last night. So Jamex will be sending it out to you tomorrow, it will go Priority, so you should get it Friday.
Once again I apologise for the delay.
:D cheers :)
Any luck with finding an r34 turbo to start the next group buy SK???
I have done a couple of high flow R34GTT turbos for guys, there is one at GCG right now as it happens. But they have supplied the turbo for high flowing. When I find one I will start a new Group Buy as I have done for the R32GTST high flows.
:blink: cheers :D
:sleep: i got my turbo to day!!!
i took a while but...
Oh well you get that....
i cant wait to put it on!!
Thanks Heaps Gary....
:D i got my turbo to day!!!
Sorry about the delay, I ran out of exchange turbos
Let me know how it goes for your.
:P cheers :)
Guest
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
