Hey there, have got all the parts for my engine swap (rb30) into my cefiro and it should be built soon. Problem is i have a turbo rb20det gearbox but i dont think it has a chance of holding the power of the rb30.
The rb30 should be running with a gt3540r turbo and around 22psi so hopefully over 300kws atw.
I can get a gearbox (r33 gtst) from japan for a good price however arent to certain what bits id need to use to convert the car from auto to manual.
I had a parts skyline so have all the rb20 conversion parts from there however the r33 box has an electronic speedo, different tail shaft, different crossmember id presume, is a different length, and has a different arrangement of clutch (push vs pull, not sure what one).
Ive heard the clutch arrangement of the series 1 boxes is the same as the rb20det boxes however thats not confirmed.
Can anyone post up some info on what id need to modify and change to get this box going in my a31 cefiro(same an r32 skyline)
Cheers
https://www.sau.com.au/forums/topic/121135-r33-gtst-box-conversion-to-a31-r32/
Dude do a search in the cefiro section. Make sure you open the seach up to all dates not just the 30days which it defaults too.
I've done it, its definately worth it. I did a big write up about it. Peace of mind. But if you cant sell the RB20 box just use it till it dies. Save your money.
Dunno about the auto to manual bit though.
Hi there. I put a 25 box in my old r32. Bits you need are or need to do, re drill your cross member, you need a r32 gtr speedo drive,and you need to mod your tailshaft in length and change the yoke to a rb25 one they are heaps bigger! Changing from auto to manual you need a clutch master cylinder and clutch pedal and either change the brake pedal to the manual one or cot that one neatly and put a new rubber pad on it.Plus you will need a clutch line from master cylinder to slave cylinder, not sure bout computer but.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
