Hey guys,
Its been bugging me for a while and managed to record the boost stutter on my gauge today (Defi). Anyhow, basically what happens is when you give it abit of a boot from off boost to on boost, if you do it gradually or in a higher gear, it stutters...
It was evidant through the playback of the gauges, that the boost needle was vibrating at certain points and slowly reaching full boost. It didnt stutter all the way, just sometimes...
Its kinda weird and bugging me, that maybe its just the bleed valve im running that came with the car, or possibly the actuator could be stuffed? Most noticeable it happens when going up hills and putting the gas on...
Any ideas would be appreciated.
Car type: s15
Mods: STD Jap spec BB turbo, FMIC, Pod, full exhaust, bleed valve boost controller, GFB Stealth fx BOV (set to plumback)
It is called "compressor surge", sounds like an atmo BOV but when you are on the power and does not happen on FULL throttle.
Unfortunately there are are few things that can cause this.
1/ The type of boost controller
2/ The turbo actuator
3/ ECU tunning
4/ The turbo.
First two are obvious; try an electronic boost controller (EBC) and fit a new turbo actuator. Unless you have a friend that lets you borrow parts off his car you may buy both items and still have the problem :D.
ECU Tunning: Some people have managed to remove or reduce the surge with more tunning. Not sure what needs to be done, but i have read that the tune can remove some/all of the surging problems.
The turbo: This usually happens with a "hi-flow" turbo. The turbine wheels used are mis-matched or slightly too big for the housing. This makes the turbo compress too much air for the engine, thus bounces back into the turbine.
Also test you BOV. Remove it and block the hole (temporarily). Go for a drive and see if the "surge" occurs.
I am not a mechanic, just what i have learnt through my experience, forums and chatting to various people. I had the same problem; this surge and the excessive lag (550hp hi-flow) made me buy a genuine HKS turbo, problem solved......... :).
Good luck.
Thanks for the replies guys, ill swap back to the std BOV and try a different boost controller when I get the chance too :D
Car still has the std ecu, but will be getting the PFC treatment later on :D I dont know if its full compressor surge, cause I know what that feels like :)
Its just when its boosting, that if you only give it partial stick where it makes boost gradually in comparrison to full stick, which opens it right up, then it usually has this problem.
I also tend to get abit of boost spike which aint cool :D I think im going to purchase an EBC, i used to have the std valve set up with a turbosmart boost t and never had any dramas what so ever in terms of spike and surge...
Sounds like a missfire under load
Thanks for the replies guys, ill swap back to the std BOV and try a different boost controller when I get the chance too :)
Car still has the std ecu, but will be getting the PFC treatment later on :) I dont know if its full compressor surge, cause I know what that feels like :P
I also tend to get abit of boost spike which aint cool :( I think im going to purchase an EBC, i used to have the std valve set up with a turbosmart boost t and never had any dramas what so ever in terms of spike and surge...
Thanks for the replies guys, ill swap back to the std BOV and try a different boost controller when I get the chance too :P
Car still has the std ecu, but will be getting the PFC treatment later on :) I dont know if its full compressor surge, cause I know what that feels like :D
What i highlighted in red is compressor surge. Only occurs on partial throttle and acts fine on full throttle.
I think a misfire would also occur, if not get worse, under full throttle.
Mine is doing this too... If I'm on WOT, generally it doesnt do it (only sometimes)...
Part throttle though, it will surge about twice a second while boosting, and give a noticible surging effect to the acceleration! Its very weird! It's almost as if an actuator isnt able to hold the pressure and is creeping open (or closed) when high boost is reached then it drops and then builds up again and so on...
Cool thanks for the input Al.
Ill be trying a few things soon. Going to buy an EBC since I want one anyhow for gadget factor and to protect the car from overboosting. Also ill be getting a bigger fuel pump which is needed anyway, cause Im going to up the power shortly by using a PFC.
I checked the valve today, its on partial atmo, like slight atmo, but mostly plumback. I do get a fair few shares of backfires tho.
Is there anyway to vent more pressure to reduce this surge on the compressor wheel?
P.S i dont feel like buying a hks turbo :laugh:
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
