yer she is pretty tidy.. however.. im having a bit of a problem.. at about 4,000rpm she starts poping.. like back firing.. till about 6,000rpm.. im really worried.. its very gay,.. and im sure its not good for the car..
any ideas?
do you have a boost gauge in it? (can't tell what that gauge is on the dash from those pics)
if so, what boost are you running?
oh, and welcome :D
The car looks excellent, and the paint is in really good nick judging by those photos... its making me jealous... :(
im from the northside, i'd rather not say what i paid.. but i didnt pay what they wanted for it.. ;-) lol
i bought some iridiums today for her.. + a new oil filter.. and im gonna do a big service on her.. see how she coems up after that..
i really wanna meet some of u guys.. get to know more people.. i get people in skyliens looking at me.. and im never to sure if there members on here.. LOL
dammit.. why do i always read this forum to late.. lol.. sorry i missed ya tim "booosted33" .. tday i transfered my personalised plates over from my mazda to my liner..
look out for PSH77
oh and yer man.. i always use 98ron fuel. so im not sure.. i think its runnign way to rich.. it pops every now and again to after gear change
please GOD dont let it be coil packs or something expensive...
Edited by WANNAR32
-If your running an A/M BOV make sure the spring is tight enough...
-Could very well be coilpacks or ignitor pack :
-What boost are you running> Could be boost cut
If you just bought it I would be going and getting up Street Machines :P
Edited by Drift_Limo
I met with him last night, funny thing is i knew him before that. Hes got iridium plugs to put in and a few minor things to do to see if he shrugs that problem. I also told him to go get up street machines though :P. Very nice clean 32 in all respects though, he will have alot of fun with it :D
Nice car bro... Just to think That car could have been mine if I didnt go for the car with the lower kilometer's hahahaha.
You must hav bought that car strait after I bought my R32 from there. yours was one of my THREE....
Lower K's steered me away from yours....
Only problem with my car was they left LOCK nuts on, and I had to get them "SMASHED" off cause they didnt have keys the dirty kunts. GREAT CAR THO :-)
Edited by -=white angel=-
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
