As I have just rebuilt my GTS4 RB20DET from Blind_Elks old AWD RB20DET by using the good crank and rods back into my block with my good pistons and rings I dont need to keep the following a secret anymore. :unsure:
Steve in QLD has Stagea RB25DET's for sale at good prices IF
you can get hold of him on 0433 413 791 or mister_gtraustralia@iprimus.com.au
You could also consider getting the $450 adapter plate from the guy in ACT (cant remember SAU username) to use a std RB25det on the AWD sump.
  • Replies 48
Hey Blind elk,
" The Stagea runs 4.083 diff ratios - it is relatively easy to swap your current diff (crown wheel AND pinion gear) into the Stagea housing. I eventually changed to the Stagea ratios front and rear, because the RB25DET had so much more torque that I didn't need the standard (R32) 4.375 ratios"
That sounds pricey man.... can u give me an estimate using aftermarket bits please.
Greatly appreciate the feed back people.
I think this topic will be of good use to future ppl who want to do this . And i believe i be the 1st to post info n progress aboutit. So its good for all =)
Keep your ideas n opionions coming !
SHorty =)
the front crown gears 2nd hand are arround 450bux i highly suggest if u buy a stagea engine get a stagea crown gears for you diff as elk pointed out the RB25DET has alot more torque than the DE and if u think u will want to luanch you car against a few GenIII v8's go for the stronger gears
where do you work i get off @ 1pm tomorrow if its good for you my phone is in my profile
Edited by Madaz
ah yeah. if you want to use a r33 gtst motor you would need a sumper adaptor plate. same thing they use for putting RB30 engines in to GTS4 or GTR skylines. would be the easyest way to do it.
good luck in your goal. rember for your budget work out an estimate and add $1000 and that should keep you sweet for any unexpected problems.. well minor ones.
Thanks BADR33 for your words of wisdom =)
It be good experience in life for me lol.... NA to TUrBO... its like losing ur virginity.... LMAO
well maybe not.
Does any one know where i can get a hold of this Adaptor plate for rb25det to 4wd sump in adel? :)
Edited by shorty_01
i will take u to a good mechanic tomorrow and we will get sum sound advice (not saying shaun from boost worx doesnt know his stuff)
**edit**
nice 4door BADR33
Edited by Madaz
Hello,
i`m about to do such conversion in the near future. I have S2 ENR33`97. It already has ENR34 manual box and ECR33 5stud brakes -- so now its gonna be the final step.
Engine was purchased this winter from the accidental auto WGNC34. It is RB25DET NEO RC4.083.
Already done:
- Oil sump changed (i didn`t want to disassemble my engine so i get a spare ENR34 oil sump with the same RC4.363).
- Timing belt, belt bearings, oil seals and water pump changed 4 new.
- stock ECR33 intercooler installed.
- stock ECR33 airfilter box installed (stock ENR33 will interfere with the intercooler outlets), you can use low resistance filter like Apexi instead.
- fuel pump changed to stock WGNC34 25DET
TODO:
- Pull out bitchy auto pilot bearing (i`ve done this once during manual conversion, but it was a bad way of doing this :D)
- Change ignition plugs.
- Maybe change high-pressure tube for power steering -- if i will find one undamaged for R34 (NEO has a mechanical valve for adding some air during idle when PS loads engine -- R33 pipe has no place for such valve)
and finally swap it! :D
The problem is that new engine is NEO -- it is quite difficult to use NEO ecu and harness at R33. I will try to leave my R33 harness and use stock ECR33 ecu. The questions that are still open is wiring for:
- TPS (will try swap TPS sensors)
- AAC/FICD system (quite different systems, not sure yet)
- VTC solenoid (will try rewiring)
- Boost solenoid (funny, but ENR33 has harness for it, but NEO connector differs, will try to rewire)
- FPCM -- optional, car can run without it, will try ti fix it later with parts from WGNC34
I think this is all you need to know for a swap :). Ask me a question a couple of weeks later -- maybe i will finish my swap.
p.s. Don`t forget about exhaust -- afaik exhaust can be used from ENR33 from cat, before the cat (downpipe, frontpipe) exhaust system is 25DET unique. It is strongly advized to change exhaust to 25DET fully cause N/A system will affect the engine perfomance.
Hello,
Already done:
TODO:
I think this is all you need to know for a swap :D. Ask me a question a couple of weeks later -- maybe i will finish my swap.
Hey mate, Thanks for the info!!!
So you have a na s2 GTS not R33 GTS4 correct? :(
Post here once you completed the conversion n tell us how it goes.
Are u getting a Engineers Certificate?
Reagrds
Shorty
Edited by shorty_01
So you have a na s2 GTS not R33 GTS4 correct? >_<
Reagrds
Shorty
I have NA R33 GTS4. RB25DE, 4WD. I`m doing most of the job myself cause i don`t trust anyone -- i`m sure i can do it better :nyaanyaa:
I have NA R33 GTS4. RB25DE, 4WD. I`m doing most of the job myself cause i don`t trust anyone -- i`m sure i can do it better >_<
and if not u can stuff it up just as good as sum1 else :nyaanyaa:
good luck on the job man me and shorty took a look under the bonnet of mine (who sum1 converted) and there is a fair bit to do
has you crown and pinion gears been changed for the turbo or are u gunna keep it orriginal
Thank you, i`ll report here after finishing swap.
p.s. i`ve changed oil sump assy (oil sump is assembled with the front diff) already -- so i now have final ratio 4.363 both front and rear. It is very short ratio, bad for highway and fuel economy, but good for city and fast launches >_<
Hey guys,
first of all i just like to thanks Madaz for showing and taking me for a spin in his MAD AZ 4 door gt4 turbo'd F*Ing charged skyline :D
What suprised me was that t Madaz did a bolt on turbo conversion running 10:1 compression with moderate boost level n not an RB25DEt engine as i first thought. However this car is mean ass! I been 200kws @ rears skylines n this feels just as fast n handles like a dream!
Im going to mechanics with Madaz soon to get my car sus's out for a turbo conversion instead of engine transplant it will work out cheaper... well hopefuly... :P
Good shizzle!
Regards SHorty
Edited by shorty_01
**edit**
nice 4door BADR33
cheers man. it will be changing again soon once the 5stud is on cus ill get some new wheels. plus a few suspension goodies. :(
plus i will start on my custom side skirts to make them fit alot nicer then they did before..
good luck to all you guys and your projects. good to see some people working on NA skylines even if its making them turbo :wave:
---------- RB 26 to RB 30 block sump adapter plates, 10mm cadium mild steel laser cut plate, with detailed photos and instructions of fitment and further minor mods $450. Please PM for further details.------------
Fitzpatrick Speed Works is the guys SAU nick.
http://www.skylinesaustralia.com/forums/in...hp?showuser=193 <--- link to his details
hope this helped the peole that want to use non gts4/gtr blocks into gts4/gtrs
any of you guys thinkin about non turbo to turbo conversions thought about using a aus spec RB30 bottom end in theres? im about to build a wrecker spec rb30det (rb30 r31/vl bottom end with r33 gts head) for my car and should make HUGE power figures. check out the RB30 thread for all the info. if you can do the bolt up work yaself i dont beleive it will be overly expensive.
i should know in a couple more how it all actually goes
thanx
Dan
Edited by NosDan
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
