man where where would you go to get a 4inch exhaust made up, i think the extreme bit would be that fat pipe hanging 4 inchs lower than the rest of your car
True it would hang down a bit...
I was offered this exhaust from someone for $1000.00 it’s from the cat back and it's made of titanium.
That’s why I was asking about the size...
It's in a shop in box hill down Station Street. It’s on display but the guy who owns it was asking me if I was after it. He said it’s a copy of the veilside r32 gtr drag car exhaust and a customer had ordered it but it was taking too long to arrive from Japan so instead the customer had decided to just get something else.
https://www.sau.com.au/forums/topic/121323-exhaust-sizes/#findComment-2239350
$1k for a cat-back titanium exhaust IS cheap.
Also, it wouldn't hang 4 inches lower underneath it would hang about an inch lower than a 3 inch exhaust which if fitted/made correctly doesnt hang that low at all (providing standard ride height is kept).
https://www.sau.com.au/forums/topic/121323-exhaust-sizes/#findComment-2244320
this may be slightly off topic but why do soo many ppl only have cat backs ? wouldnt any turbo car have a better gain from a turbo back ? and for the small amount of extra money its not liek ppl cant afford it ?
https://www.sau.com.au/forums/topic/121323-exhaust-sizes/#findComment-2247004
It was only 12 months ago that I got a full 3 inch from turbos back fitted, I’m running a pair of garret GT25 60R 14psi atmo.
Will there be much difference if I was to fit a full 4 inch from turbos back.
I would like to hear some feed back if anyone else is running a 4 inch and see the differences to 3 inch system.
https://www.sau.com.au/forums/topic/121323-exhaust-sizes/#findComment-2247573
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
