saw DR GTR and nearly got caught by cops
ae86
 Share
hey man i saw you at the cowpasture rd i was cruising and bored where the road work was !
i did a u turn cause i saw u guys and full speed to catch up but u guys had already been to far ahead where were you guys going anyways ? i think friskii or some silver GTR or GTST was with you also
btw did u see the cops that the camry got pulled over so lucky !! i slowed down
then i happened to go cumberland from john st turning off at the shell petrol station i full wheel spinned by accident because i had my stock balds on at the lights ( my deep dish were to wide had guard rubbing getting them rolled ) and they were turning yellow so had to go i think there was a red light camera there also, i was so lucky the cop full stared at me could they write down my licence plate and catch me as they were oncoming parked traffic because they witnessed the whole incident and i full sped of in fear of getting pulled over =( lucky i guess they were on the other side with the median strip =)
well yeh anyways do you guys have a cb or something ? i think i heard some talking on channel 33 if i am correct is that the channel you guys use ???
damn i talk to much and probably boring you guys well laters anyways.
Just got to work.......WOOHOO
Me & Minh were in Chinatown before I got to work and saw Donnie & Zoran cruising in the beamer looking for a place to park. I offered him a spot in my secure work car-park & he said it's too far to walk back to chinatown.....DONNIE YOU LAZY BASTARD IT'S ABOUT 2 MINUTES!!!!!
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
