saw DR GTR and nearly got caught by cops
ae86
 Share
hey man i saw you at the cowpasture rd i was cruising and bored where the road work was !
i did a u turn cause i saw u guys and full speed to catch up but u guys had already been to far ahead where were you guys going anyways ? i think friskii or some silver GTR or GTST was with you also
btw did u see the cops that the camry got pulled over so lucky !! i slowed down
then i happened to go cumberland from john st turning off at the shell petrol station i full wheel spinned by accident because i had my stock balds on at the lights ( my deep dish were to wide had guard rubbing getting them rolled ) and they were turning yellow so had to go i think there was a red light camera there also, i was so lucky the cop full stared at me could they write down my licence plate and catch me as they were oncoming parked traffic because they witnessed the whole incident and i full sped of in fear of getting pulled over =( lucky i guess they were on the other side with the median strip =)
well yeh anyways do you guys have a cb or something ? i think i heard some talking on channel 33 if i am correct is that the channel you guys use ???
damn i talk to much and probably boring you guys well laters anyways.
Just got to work.......WOOHOO
Me & Minh were in Chinatown before I got to work and saw Donnie & Zoran cruising in the beamer looking for a place to park. I offered him a spot in my secure work car-park & he said it's too far to walk back to chinatown.....DONNIE YOU LAZY BASTARD IT'S ABOUT 2 MINUTES!!!!!
 Share
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
