Hey all,
I got a problem with my R33, everytime i go over a bump or if the road is alittle bit rough, the car seems to sway side to side like i'm going bush bashing or something, the car just feels really unstable sometimes at the slightest bump.
The car was fine until i got it back from the tuners when i had the SAFC tuned on the Dyno, i dont know if something is broken or loose.. any help would be appreciated thanks
https://www.sau.com.au/forums/topic/12135-car-swings-side-to-side-over-bumps/
Good thinking K
Actually, i remember once with my car on a dyno the hicas light was coming on. after a few goes of the operator getting in and
out of the drivers seat, the steering had been turned a considerable amount. hicas kicks in at approx 80+kmh and tries to turn the rear steering, which of coarse it cant do cause the rear wheels are wedged into the rollers.
dont know if this could break anything, but worth consideration.
hey guys!!
i seem to have the same problems as Drivebai is experiencing and did a hicas diagnostic on the car just before..
the codes i recieved was
3 long flashes..........followed by 2 short flashes..........and then 1 extra long flash
does anyone know how to read these codes properly??? my guess is that its either saying
first 2 long flashes means there is a fault
2nd long flash is the first didgit = 1
2 shorts flashes = 2
meaning:fault no#12 - Hicas motor power supply not present
or
3 long flashes = 3
2 short = 2
meaning: fault no#32 - engine signal not present???? (i have no idea im lost)
could someone much more cluey give me a second opinion on this !!
CHEERS!!!!
I have HICAS error codes 22 and 32, and I've got permanently heavy steering, but no HICAS light on ever. Anyone know how to fix this?
EDIT: My car also has the sideways movement over bumps too. It's really annoying. Even driving on a slightly bumpy road gives my arms a workout trying to keep it steady.
Mic33r - did you check out that site i posted earlier..
yeah my car doesnt swing that bad.. it just kinda wobbles abit and is very annoying.. also the other nite i gave it a squirt of the line and the rear was bouncing up and donw while losing traction where as before the tyres would just screech...
also does that if i go round corners really fast.. i rang up justjap and they think it more than likey the shocks or a loose bush somewhere i will have to test out the hicas diagnostic thing as well.. although my hicas light doesnt come on either...
let us know if you find a solution
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
