Hey all,
I got a problem with my R33, everytime i go over a bump or if the road is alittle bit rough, the car seems to sway side to side like i'm going bush bashing or something, the car just feels really unstable sometimes at the slightest bump.
The car was fine until i got it back from the tuners when i had the SAFC tuned on the Dyno, i dont know if something is broken or loose.. any help would be appreciated thanks
https://www.sau.com.au/forums/topic/12135-car-swings-side-to-side-over-bumps/
Good thinking K
Actually, i remember once with my car on a dyno the hicas light was coming on. after a few goes of the operator getting in and
out of the drivers seat, the steering had been turned a considerable amount. hicas kicks in at approx 80+kmh and tries to turn the rear steering, which of coarse it cant do cause the rear wheels are wedged into the rollers.
dont know if this could break anything, but worth consideration.
hey guys!!
i seem to have the same problems as Drivebai is experiencing and did a hicas diagnostic on the car just before..
the codes i recieved was
3 long flashes..........followed by 2 short flashes..........and then 1 extra long flash
does anyone know how to read these codes properly??? my guess is that its either saying
first 2 long flashes means there is a fault
2nd long flash is the first didgit = 1
2 shorts flashes = 2
meaning:fault no#12 - Hicas motor power supply not present
or
3 long flashes = 3
2 short = 2
meaning: fault no#32 - engine signal not present???? (i have no idea im lost)
could someone much more cluey give me a second opinion on this !!
CHEERS!!!!
I have HICAS error codes 22 and 32, and I've got permanently heavy steering, but no HICAS light on ever. Anyone know how to fix this?
EDIT: My car also has the sideways movement over bumps too. It's really annoying. Even driving on a slightly bumpy road gives my arms a workout trying to keep it steady.
Mic33r - did you check out that site i posted earlier..
yeah my car doesnt swing that bad.. it just kinda wobbles abit and is very annoying.. also the other nite i gave it a squirt of the line and the rear was bouncing up and donw while losing traction where as before the tyres would just screech...
also does that if i go round corners really fast.. i rang up justjap and they think it more than likey the shocks or a loose bush somewhere i will have to test out the hicas diagnostic thing as well.. although my hicas light doesnt come on either...
let us know if you find a solution
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
