I have one and I cannot fault its performance. Quality of the piping could be better though, and you may require some modification of either the kit or your car parts to fit properly (eg in the R33 some trimming of the radiator fan blades may be needed to fit the piping).
https://www.sau.com.au/forums/topic/121381-just-jap/#findComment-2237674
thx for that appreciate ur help
https://www.sau.com.au/forums/topic/121381-just-jap/#findComment-2237767
You only get what you pay for. Look at the material and build quality of Jap kits (e.g. Blitz, HKS, Trust) and compare it to a $500 eBay job. It will speak for itself.
Then again, the eBay job might be sufficient for what you want. Always modify your car to a purpose or you'll get lost in a sea of parts. Work out where you want the car to be when you finish, and plan your mods around that. No use putting a top notch intercooler on if you dont plan on running some serious boost.
https://www.sau.com.au/forums/topic/121381-just-jap/#findComment-2238305
I have a Just Jap cooler, almost all my friends have Just Jap coolers, never seen one of them with a problem, and they seem to cool just fine.
That being said none of us are running huge horsepower or huge boost, so I can't comment on that. For dailydriving cars or cars with basic mods I don't see how you can go past them.
https://www.sau.com.au/forums/topic/121381-just-jap/#findComment-2238353
Thx for all the comments not looking to for hudge power just want a cooler that that will work well not looking to boost my car past 10 psi besides r34 gt-t turbos not recomended to be boosted past 10 psi.
thx for all ur help looks like i'll be getting one. :unsure:
https://www.sau.com.au/forums/topic/121381-just-jap/#findComment-2238752
thx for all ur help looks like i'll be getting one. >_<
On my old R33, i was pushing 211rwkw on the std turbo, with a justjap type 1 kit. Had the kit for well over a year and held up very nicely. It also was used for trackwork with no dramas.
Installed many of these kits for people on SAU, and definately a value for money kit.
No need to pay the famous brands for their marketing and its not always "what you get is what you pay for"
Definately the kit is a easy 10/10 :)
https://www.sau.com.au/forums/topic/121381-just-jap/#findComment-2247796
the problem with the delta fin is there will be more damage to the fins if a rock bounced up and hit it because of the design, but thats me nit picking.. has anyone had any experience with the delta fin because im thinking of getting one.
https://www.sau.com.au/forums/topic/121381-just-jap/#findComment-2247963
Have you seen them up close? I dropped by there yesterday and was having a look at one for my R32 and took some pics, let me find them and I will post them up.
VERY nice looking intercooler!
https://www.sau.com.au/forums/topic/121381-just-jap/#findComment-2248122
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
    • Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html
