oh hell yeah... i loved my justjap cooler.. will prbably get another for my r32... great quailty... pressure drop was non existant at 10psi and cooling efficiency was fantastic
i think unless your persueing massive horsepower.. hks and other brandy are just a waste of money
-Ruffels
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2248487
so by gathering most peoples commnets, say 250rwkw would be sufficient for just jap coolers?
Easily, they have customers running their bar and plate intercoolers on heavily modified vehicles running between 300-400rwkw happily
250-300rwkw is no problem at all.
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2248819
Yup a friend of mine bought a delta fin core when it first came out. THink it was last year!! Worked great on his modded 33.
Justjap sell the delta fin core for 199. Not to sure on cost of piping or the whole kit deal.
But very nice looking core indeed.
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2248889
I had one of those delta fin cores which I bought when they first stepped into australia. Had it on the car for over a year, and had no dramas what so ever, was pushing 211rwkw.
Looks nicer than the typical bar and plate cores, and efinately lighter...
If anyone wants to buy my tube & fin genuine hybrid core, its up for grabs as im keen on another delta fin one :)
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2249328
Yep, i have one on my R33 GTR 326rwkw no problem I have an inlet temp gauge plumbed after the intercooler and my inlet temp even on the dyno with 25psi is 40degrees max, on the street it is normal to read just over the days temp.
Awsome for the price :)
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2249879
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
