oh hell yeah... i loved my justjap cooler.. will prbably get another for my r32... great quailty... pressure drop was non existant at 10psi and cooling efficiency was fantastic
i think unless your persueing massive horsepower.. hks and other brandy are just a waste of money
-Ruffels
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2248487
so by gathering most peoples commnets, say 250rwkw would be sufficient for just jap coolers?
Easily, they have customers running their bar and plate intercoolers on heavily modified vehicles running between 300-400rwkw happily
250-300rwkw is no problem at all.
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2248819
Yup a friend of mine bought a delta fin core when it first came out. THink it was last year!! Worked great on his modded 33.
Justjap sell the delta fin core for 199. Not to sure on cost of piping or the whole kit deal.
But very nice looking core indeed.
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2248889
I had one of those delta fin cores which I bought when they first stepped into australia. Had it on the car for over a year, and had no dramas what so ever, was pushing 211rwkw.
Looks nicer than the typical bar and plate cores, and efinately lighter...
If anyone wants to buy my tube & fin genuine hybrid core, its up for grabs as im keen on another delta fin one :)
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2249328
Yep, i have one on my R33 GTR 326rwkw no problem I have an inlet temp gauge plumbed after the intercooler and my inlet temp even on the dyno with 25psi is 40degrees max, on the street it is normal to read just over the days temp.
Awsome for the price :)
https://www.sau.com.au/forums/topic/121381-just-jap/page/2/#findComment-2249879
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
