Hey guys
Gettin around to upgraded my braking on my r32gts-t(currently running stock with bendix pads).
Now what i have purchased so far are Project MU Type NR front pads, CSC braided lines front and rear and a cusco cylinder brace. Plan to run the bendix ultimates on the rear.
Now my discs look very good, i am pretty sure they have been replaced in the not too distant past. Should i upgrade my discs(front at least) to slightly larger slotted rotors?
Will i notice much difference between these and the stock but in gc discs with the afore mentioned mods.
Just wondering if it is worth upgrading the discs for little gain. Car is a street car with occasional track days and plenty of mountain runs.
https://www.sau.com.au/forums/topic/121424-brake-upgrade-question/
My 2 cents.
Use what you've got till it's dead ( unless you're planning on getting serious on the track ) and then if you choose to upgrade, do a complete upgrade like R33 GT-R Brembo's + discs etc etc. or UAS package.
I upgraded from R32 GTS-T to R32 GT-R brakes ( discs + calipers ) and would have to say it was not "really" worth it.
My 2 cents.
lol, but arent 32gtr and gtst brakes fairly similar anyway.
I want a package that is insane for the street, and really good for the track(mind you i dont do many track days). I think a brembo kit etc is alot of money wasted that i could have spent better elswhere. My 32gtst is alot lighter than a gtr anyway.
Thanks for the input anyway
well your setup will be alright for the street and a bit of track, but not insane for the street and really good for the track as you say. I would just keep what you've got and kill it then upgrade personally.
If I was going to go 'insane' for the street and 'really good' for the track...
DBA 5000 rotors (as big as you can fit under the wheel really) front, slotted/vented DBA (maybe 4000 series) on the rear.
Brembo 4 pots or some sort of 6 pot up front, 2 pots on the back.
All braided lines/master cyl stopper of course
Bias adjuster
Ferodo DS2500 or better front pads, at least RB74's on the back.
I would see how you go with current setup before spending money on upgrading (which could be better spent elsewhere)
what tyres are you using? usually tyres tend to be more important, so unless you are getting obvious brake fade i'd be investing money on tyres instead.
Edited by MerlinTheHapyPig
That paragraph makes little sense.
If your aim is to have a really impressive braking system that will handle the rigours of your average track day, why are the Brembos a waste of money? Are you scoring a good deal on some other caliper / rotor upgrade?
If you were only after a reasonable street / average track setup then it'd be overkill, but if you're planning to get something that won't fade out on your GTS-t no matter how hard and often you stand on the brakes in a 15 minute session then they'd suit the job.
Sorry i dont understand. I know that brembo calipers plus big discs etc will give me more stopping power, i understand that. Yet i dont understand how i would get more brake fade with braided lines, new good pads, new master cylinder+stopper and good fluid as opposed to the same yet with brembo calipers?
But anyway i think i have gone around the block abit, my question really was will i notice much of a difference with good stocks discs or new vented slightly larger discs with the same parts stated.
You won't get that much more stopping power per se, since the limiting factor in any modern cars' braking system is the tyres. Can you lock up the tyres with the OEM setup? Adding more braking torque won't make them lock up any later....
But what Brembo calipers and larger rotors give you is more heat dissipation. The larger rotors have more mass to absorb heat, and depending on their manufacture and materials will cope with heat better. The larger pads will give you a larger swept area (which once again means the pad heats up less in total), and Brembo calipers tend to be designed with cooling in mind.
This means that if you're doing track work you'll get more laps in at max attack before it overheats. Even with good pads, slotted / cross drilled rotors and nice fluid you can overheat brakes. Especially if you're running semi slicks.
I ran in a supersprint in February at Oran Park GP, when it was about 35 degrees ambient. With A032R's on, I was literally standing on the brake pedal as late as I dared, since the tyres wouldn't lock up due to the grip on offer. Even with DBA Slotted rotors, Ferodo DS2500 pads and Motul RBF600 fluid I managed to fade my brakes out on the 5th lap...and that's only around 7.5 minutes. If I was there for a regular track day doing a 15 minute session, my brakes would have only lasted half the session.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
