  • Replies 59
no one has beat me yet!!! :) All mine are from uni days - 'lets have a project meeting at this pub today' hahaha
I have a feeling Cam will though :yes:
"You've experienced about 59.05% of perth pubs!"
Hate to say it Liz, but you're right.. and I thought of a couple not on the list..
eg - the Mullaloo Tavern, Club X, Exotica.. to name a few.. when I'm sober I might be able to remember some more.. :yes:
Dan - sorry, had to be truthful and answer no to Connections, but I hear they have lesbo wrestling on a Thursday night.. maybe we should go have a look? :D
This doesn't make sense, if I answered YES to connections, then by a method of deductive logic, you would have to say YES too Cam :(
So that's where you took me after spiking my drink eh?? I was wondering why I couldn't walk properly the next day.. :wave:
cam we meant normal pubs not strip clubs.......... you are banned for cheating :domokun:
Liz, hula bula bar is near the sun microsystems building down that little side road I have forgotten what it use to be called....... something along the lines of the Underground bar I think........ but you should see it now spent a shitload on renovations and they serve awesome drinks........
Yer and no red windmill that place rocks. Damn you cam i would ahve been in the lead with.
You've experienced about 55.71% of perth pubs!
I cant believe ive been to over half the pubs in perth seeing as i rarely venture up north. Hmm time for new city?
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
