Ive just bought a 700hp rated turbo for my r33. its a garrett 3582R or sumthing along those lines. it isnt a 3540 i know that for sure. But i need to replace the factory ECU before i put it in. What one would be suitable for my RB25 ?? At this stage, all it will have is the bigger turbo, a front mount, and what ever ECU i choose. I will run it at about 16pound to be safe. Ive been told to buy a wolf 3D plug in for $1600. Any other suggestions ????
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/
  • Replies 54
It all depends on what you plan to with the car in the future...thats a fairly large turbo...what other mods have you got to support it ie, injectors, fuel pump etc... Power fc is probably the best if your going to get your best performance with mods however if your just going to have a couple of light mods fmic bov zoorst etc then maybe get a piggyback..
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2238517
its a 97 m spec strait off the ship from jap, ive put a 3" zorst (from cat back i think), boost control, trust BOV, HKS air pod.. at the moment all i want is more power and boost, in future ill go manifold, external wastegate, injectors, fuel pump, but right now all i want is to put my turbo on with a good computer to run it. and ill put a front mount on aswell. i want a hand controller aswell.. do u recon apexi power fc will do the trick and back up later down the track when i put the other mods on ?
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2238541
Yes power fc is your best bet mate as it is very tunable and can be tuned again at a later date when you plan to do more upgrades. If you like i can get you a price on one? As for tuning costs it all depends on where you go!
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2238561
im not very experienced with turbo cars, this is my 1st import. i was told it was a good turbo. how much boost could i run safely with that turbo without doing the internals or putting a larger fuel pump and injectors in?? I want to put those extra mods on later down the track when i save up a little more. Will it be alot quicker than a stocko skyline if i put the turbo, power fc, and a front mount on or wont it make much difference???
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2238608
a well setup skyline on the stock turbo would blow away your car with a pfc that turbo and an intercooler
average power makes a car fast
not a big turbo. its a good turbo? based on what? what do you want out of the turbo? do you want lag? do you want quick response? do you want max power? do you want a good street car? do you want to win dyno comps and nothing else?
what do you want to do with the car? what do you expect?
only then can someone say its a good or bad turbocharger or recommend one that is suitable. also a power goal will give you the answer you need
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2238678
700hp turbo running 16psi/pounds is alot of power my guess is you'll be making power around 230rwkw-300rwkw.
BUT your biggest problems is you don't have supporting mods to run that kind of power with your current setup.
My guess guys correct me if i'm wrong
Stock Fuel Pump (good for 200rwkw?)
Stock Injectors (good for 220rwkw?)
if i were in your shoes get the fuel pump and injectors done or else your engine will go BOOM! running 16psi on a 700hp turbo on stock fuel pump and injectors NOT a good idea.
OR if your really tight for funds get the front mount on, get the turbo on and RUN the lowest possible boost setting in the meantime until you can afford a fuel pump/injectors/metal head gasket. aim to tune the car for around the 200rwkw mark.
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2238696
correct the powerfc is a great computer but with stock injectors and stock pump it wont be a safe tune. youll need;
larger injectors
larger airflow meter
larger fuel pump
heavy duty clutch
some good tyres
cold air intake
suitable manifold (and gate if external)
suitable dump pipe
suitable 3" turbo back exhaust at the least (with hiflow cat)
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2238822
ive got stock injectors and fuel pump, atm im on 232rwkw with aftermarket turbo.. he would be able to get around 240-250rwkw before maxing out the fuel pump, injectors can go a bit more maybe 260rwkw..
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2240014
stock inj are good for 230-240
stock AFM maxes at near 210
Cams at 235
16psi boost on that turbo with computer, cams, AFM and inj upgrade will get you 320rwkw.
Without upgrading any of these things will cause the Boom you speak of. This should be interesting to watch.
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2240584
whilst its all good and fun to have 320rwkw on
ecu
cams
afm
injectors
what about the important stuff that makes it driveable?
whats the point of all that power will crappy tyres, stock suspension, stock clutch and other various components that help make the turbo upgrade worthwhile. a lot of people these days are into the habit of just grabbing any old cheap ebay turbo or garrett reseller $xyz$ and then bolting it and fitting mods (only bare essentials)
to me, i dont see the point, it would suck and be frustrating
https://www.sau.com.au/forums/topic/121435-turbo-upgrade/#findComment-2240717
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
