The wheels shown on Tempe Tyres website are more often than not replicas of JDM wheels.
They are going to be more heavy and suffer an inferior finish/quality compared to wheels made by the more popular Japanese wheel manufacturers.
Finally, if you get the package, it means that the tyres that come in the pacakage are low end Falken tyres (ZE326s) which offer very poor levels of grip both in wet and dry conditions.
https://www.sau.com.au/forums/topic/121457-tempe-tyres/#findComment-2239003
I picked up some Impuls second hand with wide rubber and for the money it was a great deal. These originally come from Tempe and I like the look of them personally, they are not the lightest rim or the strongest, probably not suitable for track work.
Cheers
https://www.sau.com.au/forums/topic/121457-tempe-tyres/#findComment-2239718
Chrome finish is pretty poor. Mate has some and the chrome peeled in 2 months. Could just be a faulty batch, however they said it was not a warrant issue. So on that basis, i personally would not purchase from them.
Regards
R Dirty 3
https://www.sau.com.au/forums/topic/121457-tempe-tyres/#findComment-2240208
Regards
R Dirty 3
Finish is the least of your problems. They are cheap cast Chinese rims ( cheap and nasty), i wouldn't use them on a GTR thats for sure.
https://www.sau.com.au/forums/topic/121457-tempe-tyres/#findComment-2240829
apart from the popular [b00S7A] pic going around, has anyone seen evidence of these rims cracking or breaking due to stress etc? even then, i doubt that the BOOS7A case was due to weak wheels either...
Edited by _8OO5TED_
https://www.sau.com.au/forums/topic/121457-tempe-tyres/#findComment-2241668
Matt: I mounted a gutter avoiding an idiot with my Imupls and carefully inspected the rim and there was no obvious damage visible. (Side note: did you end up calling my mate about his insurance?)
Xizor: Blah! Get something with Dish :(
https://www.sau.com.au/forums/topic/121457-tempe-tyres/#findComment-2241693
Bryce was it? Done :(
I would never pay $150 for a rim, firstly it would be damn small and secondly, I would have to agree it would be pretty p*ss weak too. Probably why I paid $800 per rim....
https://www.sau.com.au/forums/topic/121457-tempe-tyres/#findComment-2241784
Yeah I originally wanted 17's for the same reason but came across my set of 18's with brand new Nankang Ultra Sport II's (235 front 265 rears) for $1200 total So i couldn't resist.
Back to the topic though... Tempe sell cheaper wheels and tyres and as such the quality is not at the same standard as some of the JDM sets.
Funk: You might be better off looking around for some 2nd hand JDM's f you're concerned about qiality/strength/weight etc.
Good luck and show us pics when you get some wheels.
https://www.sau.com.au/forums/topic/121457-tempe-tyres/#findComment-2241855
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
